» Site Navigation
» Other Sites
Old 02-10-2002, 12:36 PM   #1 (permalink)
Date registered: Dec 1998
hissing , and rattling noise 300e help?
ok , i just purchased a 1986 300e today and i have a couple things that need to be done, brake pads rotated tires, oil change, and transmetion fluid needs to be checked, but everything i start the car, i hear a hissing noise , and feel it vibratining when when its in park, also when outside of the car you can hear a rattle i'm guessing from the radator or something any ideas? thx
Old 02-10-2002, 12:46 PM   #2 (permalink)
Re: hissing , and rattling noise 300e help?
Hi <br> <br> The hissing noise is probably the fan belt (poly v belt). Drop some water on it while its running if the noise goes. Then there you go. If it is that put a little grease on the underside of the belt to lube. I know it sounds crazy but it works and has no side effects.<br> <br> The viabration may be engine mountings. Does the vehicle have a slight vibe when pulling off?<br> <br> Hope I have been some help.<br> <br>
Old 02-10-2002, 01:50 PM   #3 (permalink)
i'm not sure about the pulling off, ill check it out l8r but thx for the help 1 more thing about the hissing noise , i'm not postive its the belt , b/c i can hear the hissing all the way in the back near rear tires as well. sorta under neath the car thx.
Old 02-10-2002, 01:50 PM   #4 (permalink)
oh be the way this is JPE1 just on diff ;0
Old 02-11-2002, 10:51 AM   #5 (permalink)
Sounds like an exhaust leak to me. My 300E had a similar issue, but I sold it before I diagnosed it.
Old 02-13-2002, 11:03 AM   #6 (permalink)
My .02
Hissing: I'd also check the exhaust first. Especially in front of the cat.<br> <br> Rattle: Mine drove me crazy with this same problem for two years before I finally figured out what it was. On my car, there is a shock absorber looking deal that goes from a bracket on the top front part of the head to the belt tension spring housing. It has a rubber bushing on each end. They had deteriorated and fallen out. So the ends of the shock thing were rattling against it's mounting points. I replaced the shock and bushings, and the noise went away.
Old 02-19-2002, 07:53 AM   #7 (permalink)
Re: My .02
The ppl who i brought it in said it was the fuel pump defently making the hissing noise is this possible?
