Old 05-04-2001, 09:54 AM   #1 (permalink)
Date registered: Dec 1998
300E HESITATION/MISS UNDER ACCEL.
HELLO EVERYONE, I HAVE A 91 300E WITH 97,000 MILES. JUST RECENTLY IT HAS DEVELOPED A MISS UNDER ACCELERATION FROM A STOP. IT WILL ONLY DO IT WHEN IT IS FULLY WARMED UP. I HAVE REPLACED THE CAP, ROTOR, PLUGS AND WIRES. ALSO I HAVE TRIED FUEL INJECTOR CLEANER TO NO AVAIL. THE MISS WILL CLEAR OUT AS SOON AS THE ENGINE REACHES ABOUT 1500 RPM'S. I AM AT A LOSS AS TO WHAT IT MAY BE. IF ANYONE HAS AN IDEA, PLEASE DROP ME A LINE. THANK YOU...JAMES PS. THERE IS NO CHECK ENGINE LIGHT ON AND IT RUNS GREAT OTHERWISE.
Old 05-09-2001, 06:17 PM   #2 (permalink)
Re: 300E HESITATION/MISS UNDER ACCEL.
Ignition coil or fuel filter.
Old 05-11-2001, 02:25 AM   #3 (permalink)
I had a similar problem with my 1990 300CE. I found some leaking vacuum lines/rubber tees.<br> Also, try to narrow your spark plug gap from 0.8mm to 0.65mm and se if the miss clears.<br> I also had to replace the fuel distributor.<br>
