Old 04-10-2001, 05:20 PM   #1 (permalink)
Date registered: Dec 1998
Help: 300E Sportsline Conversion (suspension upgra
I searched out the info that a portsline conversion includes the following parts, which are straight forward. <p>2 x Inner Bushing 124 323 45 85 <br>2 x Outer Bushing 124 323 51 85 <br>2 x Bushing 124 326 01 81 <br>2 x Rear sub-frame mounts 129 351 14 42 <br>1 x Front Sway Bar 124 323 68 65 <br>1 x Rear Sway Bar 124 326 19 65 <p>The following I am not sure because there are 3 part numbers depend on which one fits my chassis number:<p>2 x Lower control arm bushing kit, <br>201 330 01 75<br>124 330 09 75<br>124 330 06 75<p>Or perhaps I don't have to worry about the lower control arm bushing, and just use whatever that's on my car ?<p>The car is 300E 2.8' 93
Old 04-10-2001, 06:26 PM   #2 (permalink)
Re: Help: 300E Sportsline Conversion (suspension upgra
: I searched out the info that a Sportline conversion includes the following parts, which are straight forward. <p>2 x Inner Bushing 124 323 45 85 <br>2 x Outer Bushing 124 323 51 85 <br>2 x Bushing 124 326 01 81 <br>2 x Rear sub-frame mounts 129 351 14 42 <br>1 x Front Sway Bar 124 323 68 65 <br>1 x Rear Sway Bar 124 326 19 65 <p>The following I am not sure because there are 3 part numbers depend on which one fits my chassis number:<p>2 x Lower control arm bushing kit, <br>201 330 01 75<br>124 330 09 75<br>124 330 06 75<p>Or perhaps I don't have to worry about the lower control arm bushing, and just use whatever that's on my car ?<p>The car is 300E 2.8' 93<p><br>The correct part number for the Sportline lower control arm bushings is 124 330 09 75. You'll need two of those kits. They are about $45 each from rustyparts.net. I have the full Sportline conversion on my 1987 300D, except the rear subframe bushings (haven't done those yet). <p><p>The swaybars are the easiest to do, and also the cheapest - they require no special tools. I highly recommend that EVERYONE with a non-V8 W124 upgrade to the Sportline swaybars. They don't make the ride any harsher, yet there is a noticeable increase in turning crispness. (The V8 cars - 400E/500E - have totally different suspensions and the Sportline equipment does not apply.) The rear subframe bushings may require a special tool to press in & out, I'm not sure. <p><p>The front control arm bushings require complete removal of the control arm, therefore necessitating a Mercedes spring compressor. I'd recommend changing the ball joints too while you have it all apart, and of course you'll need a 4-wheel alignment as well. The Sportline control arm bushings are MUCH stiffer than stock, they almost feel like polyurethane, but I think they are simply a harder durometer rubber. <p><p>You can also get the Sportline springs and shocks to complete the package, and at that point you might as well get the fender badges and shift knob too. I have a Carat/Eibach/Bilstein package on my car. Drop me an email if you have any other questions...
