Re: YES, W124 taillights are ALL the same size.
: : Does anyone know if the 1988 124 tail light is compatible with the 1993-1995 124's? Would appreciate your input!<p><p>Ummm.... yes, but the 1994-1995 have clear turn signal lenses, and the 1986-1993 have yellow. It's a fairly common "upgrade" to put the later 94/95 lenses on older cars, since most people think the newer ones look better. All 4 lenses (front & rear, left & right) cost roughly $250 from The Benz Bin. I plan to do this eventually, when funds permit. You'll need a yellow bulb for the clear lenses though, to be DOT compliant and keep the local fuzz off you back. They get cranky when the see clear blinkers for some reason. :-)<p>Dave M.
