Would you guys use MBZ parts for a plug and plug wire change on a 92/300E...Is there anything different about this service. Air Filter? Any good internet sources that are dependable? Thanks for your help.
carparts.com has quite a bit of stuff. I think the factory plugs are Bosch the wires might be Bosch also. You can find Bosch parts and other brands at carparts.com.<p>
: Would you guys use MBZ parts for a plug and plug wire change on a 92/300E...Is there anything different about this service. Air Filter? Any good internet sources that are dependable? Thanks for your help. <p>Comment on plugs...Bosch Platinum plugs work great and the X type (which seem to have a wider gap. in the range of 040 in.)work really well.<br>They last longer and seem to function very well. <br>Best part...get them at Walmart and the price is the lowest I can find anywhere.<br>They also list Fram Filters but never have any in stock. Worth the trip for plugs alone. Seems these are the same as on some GM products.<br>
