Car overheating - Mercedes-Benz Forum
post #1 of 19 (permalink) Old 07-11-2013, 08:01 PM Thread Starter
Date registered: Jul 2013
Vehicle: 1990 Mercedes Benz 300E
Car overheating
I've looked up this question on this site but the thing is I'm a complete newbie when it comes to stuff about cars. Anyways my 1990 Mercedes Benz 300e has had this problem for a long time now probably a little under a year. The temperature of the car will be fine until I drive for at least 15 minutes and even then it's okay but once I hit traffic or a stop thats when the temperature starts to rise; I have to turn the heater on and rev the engine while on neutral or park which helps the temperature go down a little bit. If the temperature has been hot for long enough it will throw out all the coolant and sometimes there will be a loud noise sounds like alot of pressure trying to escape and it almost sounds like it's going to blow up as it gets very loud. Here are some pictures if it helps any, and the car also has a check engine light on which may be related to the problem?
Also the arrows show that there is something missing and if it's important? the car has been doing this before these parts fell off and its been running the same.
ID:	526578   Click image for larger version
ID:	526579   Click image for larger version
ID:	526580   Click image for larger version
geralriver is offline
post #2 of 19 (permalink) Old 07-11-2013, 08:03 PM Thread Starter
i took the cap off the first picture but the first picture with the arrows was to show that i have seen the water leak out through there
post #3 of 19 (permalink) Old 07-11-2013, 08:06 PM
MichaelBenz300e's Avatar
Date registered: Dec 2012
Vehicle: 1999 e300 turbodiesel
Quoted: 32 Post(s)
Dude, is that your washer fluid tank?
MichaelBenz300e is offline
post #4 of 19 (permalink) Old 07-11-2013, 08:08 PM Thread Starter
yep
post #5 of 19 (permalink) Old 07-11-2013, 08:22 PM
sbaert's Avatar
Date registered: Jun 2007
Vehicle: '95 E300 DIESEL, '91 600SEL, '92 600SEL
Quoted: 1012 Post(s)
Leaking windshield washer coil. Very common.
sbaert is online now
post #6 of 19 (permalink) Old 07-11-2013, 08:44 PM Thread Starter
thank you for that
post #7 of 19 (permalink) Old 07-11-2013, 08:58 PM
sbaert's Avatar
Be sure to replace that coil ASAP and get the o-rings where the coil goes into the tank..
post #8 of 19 (permalink) Old 07-12-2013, 11:47 AM
benzitch's Avatar
Date registered: Oct 2003
Vehicle: 91 560SEC Beryl/Palomino 91 420SEL Black Pearl/Mushroom 89 420SEL Ice Blue/Navy 88 420SEL 94 E320
Quoted: 106 Post(s)
These are very simple things. If you can not figure these out than you are in need of a mechanic.
2) Overflow hose
3) Breather hose
Find a mechanic.
Bruce
benzitch is offline
post #9 of 19 (permalink) Old 07-12-2013, 02:55 PM
Date registered: Feb 2007
Vehicle: 94 E320
O.K. - to get back to your overheating issue. Is your electric fan working? As far as the windshield washer fluid issue, most time people just by-pass the coil that goes to the windsheild washer fluid when it goes bad. I believe the problem with the coil in the washer fluid is more of a result of overheating and not the reason, but I could be wrong. The by-pass should eliminate that concern for you to let you look for what could be causing the over-heating. Also, is the thermostat O.K.? They are easy to check - remove it and but in a pot of boiling water and it should open fully. Last item I can think of is the viscous mechanical fan, however if that isn't working right, you should still have enough cooling with the electric fan (unless you are running A/C in a very hot climate). I know on my M104 if I pull the two wire connector on the thermostat housing my electric fans (M104 has 2) turn-on, but I'm not sure that true for your model. There is also a couple of relays that control the fans that have fuses that may be suspect if your fan isn't working. Good Luck!
roycehof is offline
post #10 of 19 (permalink) Old 07-12-2013, 04:34 PM
Date registered: Oct 2008
Vehicle: '89 420SEL, '93 300E and '07 Hyu Santa Fe
Quoted: 11 Post(s)
Find a mechanic.
Don't.
You are here to learn and it's great resouce site.
As long as you are willing to learn, you will learn anything. Don't be discouraged by naysayers.....
I and many people like me are regular visitors here who never in their life touched wrench and Now doing lot of regular and advance maintenance themselves.
'93 300E 2.8, Green (205K...)
'07 Santa Fe SE, Natural khaki (95K..)
'04 S500 (122k..)
'89 420SEL, Diamond Blue (154K..) Retired
'08 kawi 250R, Red (10K..) (Sold)
MBCarGuy007 is offline
