Aux fan replacement. - Mercedes-Benz Forum
post #1 of 31 (permalink) Old 05-11-2013, 10:56 AM Thread Starter
jdmatthews77's Avatar
Date registered: Feb 2008
Vehicle: 1990 Mercedes-Benz 300E 3.0L 256K MI
Hey guys, I have a 1990 300E with the dual electric aux fans. I need to replace them as one is not working, so I think it's not allowing my newly installed ac compressor to work effectively. The ac blows warm arm unless I'm driving plus with the ac on my car runs warm at idle. Can someone supply me with instructions on removing these two fans? Pictures would be great. Thanks!
jdmatthews77 is offline
post #2 of 31 (permalink) Old 05-11-2013, 01:01 PM
sbaert's Avatar
Date registered: Jun 2007
Vehicle: '95 E300 DIESEL, '91 600SEL, '92 600SEL
Quoted: 992 Post(s)
Use the forum's search feature. The aux fan R&R instructions have been posted multiple times.
Be sure to clean out the condenser & radiator fins using a pressure washer.
sbaert is offline
post #3 of 31 (permalink) Old 05-11-2013, 01:45 PM Thread Starter
Thanks!
post #4 of 31 (permalink) Old 05-11-2013, 01:49 PM Thread Starter
Having a hard time finding it
post #5 of 31 (permalink) Old 05-11-2013, 01:57 PM
Cruise Control
Zeitgeist's Avatar
Date registered: Sep 2004
Vehicle: '87 300TD/'90 300D/'94 Quattro/'89 Vanagon TDI/'01 EV Weekender VR6
Quoted: 1632 Post(s)
Zeitgeist is offline
post #6 of 31 (permalink) Old 05-11-2013, 03:32 PM
sbaert's Avatar
Quoted: 992 Post(s)
Be sure your aux fan resistor, relays and fuses are all good and working.
At a minimum, replace the resistor and ALL the fuses with the updated copper core type.
Sometimes a bad resistor will result in only 1 fan running even though both fans are functionally OK.
sbaert is offline
post #7 of 31 (permalink) Old 05-11-2013, 08:05 PM Thread Starter
Where might I find the resistor? Price? The fan that's not working is the drivers side. I works for a few moments if I apply pressure to it, but it doesn't spin as fast as the other one. Does that other fan make that much difference in getting the ac cooler?
post #8 of 31 (permalink) Old 05-11-2013, 10:31 PM
sbaert's Avatar
Quoted: 992 Post(s)
Resistor is located behind driver side headlight unit.
Replace with BERU replacement unit only, available from autohausaz.com
sbaert is offline
post #9 of 31 (permalink) Old 05-12-2013, 02:01 AM
Jayare's Avatar
Date registered: Jun 2005
Vehicle: 86 190E 2.3L 16V, 93 400E, 95 320TE, 95 E320, 98 S500
Quoted: 687 Post(s)
For your cooling and A/C system to operate as intended, both aux. fans need to be operational. They are two speed fans. Low speed kick on with the engagement of the air conditioner. High speed kick in when your engine temperature hits approx. 105 degrees.
Jayare is offline
post #10 of 31 (permalink) Old 05-12-2013, 10:35 AM Thread Starter
Does that second fan make that big of a difference in both ac and engine cooling capacity? When the big engine fan spools up under acceleration, ac has its best performance and engine cools drastically. Plus is this idling too low when the ac is engaged? Normally idling with the ac of is about 750-800 Aux fan replacement.-imageuploadedbyag-free1368380086.277137.jpgAux fan replacement.-imageuploadedbyag-free1368380104.639367.jpg
