W124 Wheel bearing replacement technical write up? - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 03-11-2013, 04:42 AM Thread Starter
Date registered: Feb 2012
Vehicle: 1991 300E 2.6
Can anyone point me to an official MB write up on how to replace wheel bearings on a W124? I could not find it in the online maintenance manual.
1991 300E 2.6, 230K miles
Camman595 is offline
post #2 of 6 (permalink) Old 03-11-2013, 06:45 AM
DP
DP's Avatar
Vehicle: 190E, 400E, SLK350
Quoted: 1069 Post(s)
The front or the rear?
DP is offline
post #3 of 6 (permalink) Old 03-11-2013, 07:22 AM Thread Starter
At the moment, front but both would be welcome.
post #4 of 6 (permalink) Old 03-11-2013, 09:33 AM
94Wagenmeister's Avatar
Date registered: May 2005
Vehicle: 85 300 TDT
Quoted: 19 Post(s)
Send a message via AIM to 94Wagenmeister
Am also interested as I recently found out there is actually a bearing adjustment on the front that can be done. Probably only delayed the inevitable for me.
Scott in MD/DC
85 TDT the "Blue Whale"
past: W124 wagon, W126, W202, W201, lotsa VDubs
94Wagenmeister is offline
post #5 of 6 (permalink) Old 03-11-2013, 10:47 AM
Check Codes's Avatar
Vehicle: '01-E320 & 02-ST2
Quoted: 35 Post(s)
For the front, you can use the great stuff G-AMG posted in the W210 forum and linked in the help/diy stickies. Same setup, same runout/adjustment specs.
That said, replacing the front wheel bearings is little different from any other RWD car. Remove the locking nut on the spindle, remove the hub, remove the inner grease seal, remove the bearings, clean thoroughly. If they need to be replaced, buy quality stuff, remove the outer race(s) from the hub and install the new parts, being sure to pack the new wheel bearings.
The hardest part of the job is getting out the old races. Some places sell hubs with bearings, which makes it a very fast (but more expensive) job.
Wagenmeister, I would not just do the adjustment. I'd recommend removing the bearings so you can clean and repack them before adjusting them. I did the ones on my W210 at about 110,000 miles and the grease was pretty well done.
Good luck.
Check Codes is offline
post #6 of 6 (permalink) Old 03-11-2013, 12:56 PM
R.P. McMurphy's Avatar
Date registered: Dec 2010
Vehicle: 1984 300dt 1985 300 dt 1992 300e just added another 92 300e 1994 e420 1993 300te 4matic
Quoted: 272 Post(s)
R.P. McMurphy is offline
