722.3 vs 722.4 - Mercedes-Benz Forum
post #1 of 20 (permalink) Old 02-12-2013, 09:59 PM Thread Starter
Date registered: Apr 2012
Vehicle: 1985 300D
722.3 vs 722.4
At the risk of jacking another member's thread here, I decided to start another thread. Someone mentioned that the 722.3 was a stronger transmission than the 722.4, and that the .4 was also smaller.
First thing I would like to know, what are the differences between the two transmissions? overall length, shift points, reliability, anything I missed?
Second, what are the advantages of one transmission versus the other?
Third, why did MB change from the .3 to the .4?
I had other questions in mind when I started this thread, but I can't recall them at the moment.
1987 Mazda B2200 2.2L Weber 38
1985 Mercedes Benz 300D
300K+ both rides
EmJay520 is offline
post #2 of 20 (permalink) Old 02-12-2013, 11:23 PM
sbaert's Avatar
Date registered: Jun 2007
Vehicle: '95 E300 DIESEL, '91 600SEL, '92 600SEL
Quoted: 955 Post(s)
Use the search feature.
IIRC, our moderator Zeitgeist upgraded his OM602 powered turbodiesel from a 722.4 to a 722.3 trans. I think the 722.3 has a higher torque rating, thus making it a stronger box. Do keep in mind that longevity is determined by driving patterns, driving behavior, service upkeep and a bit of common sense. If you believe in the "filled for life" marketing ploys, then even a 722.3 will disappoint at some point.
While not for a novice, it is definitely doable. I intend to do the same in a few years when the 722.4 in my OM606 powered diesel is at the end of its useful lifespan. This could take a while though, since the diesel is a low miler at just over 90K original miles.
sbaert is offline
post #3 of 20 (permalink) Old 02-12-2013, 11:28 PM
Date registered: Dec 2007
Vehicle: '99 W210 E240, '96 W202 C180, '96 W202 C200.
Quoted: 18 Post(s)
Are you thinking of putting a 722.3 in your 190e?
Don't bother. There is a little bit of gear ratio differences between the 722.4 and 722.3 which make the smaller engines struggle with the larger. The diff ratio is compensated for the difference in 2 and 3 rd gears.
Besides that.
The 722.3 is longer, heavier and uses a different sized yoke to connect to the drives shaft.
Then there is the NSS electrical connector on the side. They're different. You can screw around changing this if you like.
You will need to take the car to an auto specialist to get the vacuum modulator adjusted to spec.
The cooling pipes to the radiator are different. The Banjo bolt sizes at the transmission end is different. You need to get the original 722.3 pipes and replace the 722.4 ones - a P.I.T.A. job while the engine is in the car.
The transmission dipstick on a 722.3 may not fit correctly on a M102 motor.
The torque converter is different. You need to take the T.Q. from the 722.4 and use that on the 722.3.
How do I know these things?
I changed out the 722.4 for a 722.3 on my 300e 2.6.
I had the 722.3 in four around six weeks before I changed it back to a 722.4 again.
The performance in 2nd and 3rd gears was less than satisfactory.
I wasn't happy with it.
The extra length and bulk of a 722.3 may not fit under a 190e. It may fit if your car was a 190e 2.6 but I wouldn't count on it.
Ivanerrol is offline
post #4 of 20 (permalink) Old 02-13-2013, 08:57 AM Thread Starter
Vehicle: 1985 300D
Ivanerrol, this isn't for my 190, that is a 5spd getrag and I'm keeping that till it's end. I'm actually looking more for my 2.5 swap into my project truck. Being a truck, when I saw the stronger gearbox commented in the other thread the 722.3 looked pretty appealing. I may still stick with the 722.4 for simplicity in my swap (IE not needing more parts.) I'll try to search for Zeitgeist thread, I didn't look for a swap originally which might be how I missed his thread.
300K+ both rides
EmJay520 is offline
post #5 of 20 (permalink) Old 02-13-2013, 09:37 AM
Cruise Control
Zeitgeist's Avatar
Date registered: Sep 2004
Vehicle: '87 300TD/'90 300D/'94 Quattro/'89 Vanagon TDI/'01 EV Weekender VR6
Quoted: 1567 Post(s)
Here's a link. There are some pics in there which might be helpful
Zeitgeist is offline
post #6 of 20 (permalink) Old 02-13-2013, 02:38 PM Thread Starter
Vehicle: 1985 300D
Thanks for the link, nice detail about the driveshafts and everything. Answered all but last question (why MB changed, who knows?)
Zeitgeist, if I may pick your brain for an opinion, would you rather use the .3 or the .4 for a small truck application, occasionally tow but not often? Vehicle weight factory is about 2300 for my short bed model. Rear end from factory is 3.909.
300K+ both rides
EmJay520 is offline
post #7 of 20 (permalink) Old 02-13-2013, 04:00 PM
Cruise Control
Zeitgeist's Avatar
I can't tell you why MB changed, but the internal gearing is different for each model. The .3 was a huge improvement for my 602, but that engine is slightly tweaked so that it performs better than stock. I think a .3 is the better trans for durability, so it should be more appropriate for towing.
I think your rear diff ratio is going to be an issue with either trans. The diff ratio in your current car is only 2.65. I believe 3.9 is considerably lower than the ratio used in any 602 passenger car with an auto.
post #8 of 20 (permalink) Old 02-13-2013, 07:38 PM Thread Starter
Vehicle: 1985 300D
hmm, that is going to be a fun issue. The highest rear end used on ANY of the Jap Mazda trucks was a 3.23, and that diff wasn't known for it's reliability. I'm trying to avoid needing to swap over the rear suspension from the 300 if at all possible, I don't want to have to worry about doing the front as well (I'm the type that wants all the wheels to be the same on the vehicle.) However, Mercedes wheels would look good on my truck, hmm.....
I'll do a search for the gear ratios of both the .3 and the .4 transmissions, see exactly what I'm working with. I'm also trying to figure out exactly how the speedometer gets it's signal. I just wish it'd stop raining and freezing on my days off so I can actually dive into the 300.
300K+ both rides
EmJay520 is offline
post #9 of 20 (permalink) Old 02-13-2013, 08:16 PM
Quoted: 18 Post(s)
Speedo feed for early transmission whether 772.3 or 722.4 is mechanical. For the later 722.4 post ,93 is electrical.
If you are going to try and utilise the drive shaft out of the Benz in your truck I would take the appropriate one from whatever transmission you use.
What ever transmission you use you will need to bodge up some switches for the Neutral safety switch and foot brake lockout - unless you transpose the gearshift mechanism from the Benz.
You will need to play with the vacuum modulater if you change to a 722.3
You will need to work out your diff ratios carefully.
Even though most documentation doesn't list the differing 2nd and 3rd gear ratios between transmissions you will need the last two digits of the transmission number to accurately find this e.g 722.358 or 722.320 or 722.409 etc etc
Six_wheeler likes this.
post #10 of 20 (permalink) Old 02-13-2013, 09:24 PM Thread Starter
Vehicle: 1985 300D
I was actually planning on using the shift console and setup from the Benz in my truck, fabbing a brake switch would be pretty easy I would imagine. If all else fails I have a parts car to adapt
Guess I have an even more epic build on my hands now, lol
300K+ both rides
EmJay520 is offline
