Wanted - ABS Fault codes for 1992 w124 CABRIOLET 16 pin connection. - Mercedes-Benz Forum
post #1 of 15 (permalink) Old 01-06-2013, 11:38 AM Thread Starter
Rick Dean's Avatar
Date registered: May 2008
Vehicle: 1993 300e 2.8
Hello all, Looking for ABS fault codes for 1992 w124 300CE Cabriolet 051 with 16 pin connection port. My code file listed below doesn't show it. Any help would be appreciated.
Thanks, Rick
http://mbworld.org/forums/attachment...de-scanner.pdf
Rick Dean is offline
post #2 of 15 (permalink) Old 01-06-2013, 12:24 PM
djakovic's Avatar
Date registered: Aug 2012
Vehicle: 1994 Mercedes E320 convertible 1993 Mercedes 300D 2.5 euro 1987 Mercedes 300D. 1985 Mercedes
Quoted: 56 Post(s)
Thanks, Rick
Is that a gray market vehicle? Cabriolet W124 was never available in that year in USA.
djakovic is offline
post #3 of 15 (permalink) Old 01-06-2013, 01:06 PM
stormtigers's Avatar
Date registered: Apr 2011
Vehicle: '88 "Zender" 300CE Coupe "BRUNHILDE"
Quoted: 56 Post(s)
Maybe a Japanese LHD import djakovic or else a late 1992 making it the first of the cab's in the USA maybe ?
Rick what is the engine type you have - M104.980 or M104.992 ?
The reason I ask is there are some 300CE's over there that are transition models and another member had issue finding fault codes because he was mistakenly looking at the wrong engine type and the corresponding code in that instance gave a completely different issue !
The 104.980 is a 24 valve 3 litre engine produced 217 hp (162 kW) with a 7k redline (CFI system)
The 104.992 is a 24 valve 3.2 litre engine produced 217 hp (161 kW) with a 6.5k redline. (HFM system)
# Flashes PROBABLE CAUSE for Mercedes 190E & 300 series (2.6L & 3.0L) 1991 thru 1993
1 No faults in system
2 Throttle Valve Switch (full throttle contact)
3 Coolant Temperature Sensor
4 Airflow Sensor Potentiometer
5 Oxygen Sensor
6 Not Assigned
7 TNA (engine RPM signal)
8 Altitude Pressure signal from EZL Ignition Control Unit
9 Current to Electro-hydraulic Actuator
10 Throttle Valve Switch (Idle Contact)
11 Air Injection system
12 Absolute Pressure valves from EZL Ignition Control Unit
13 Intake Air Temperature signal
14 Road Speed signal at CIS-E Control Unit
15 Not assigned
16 Exhaust Gas Recirculation (EGR)
17 Oxygen Sensor signal
18 Current to Idle Speed Air Valve
19 Not Assigned
20 Not Assigned
21 Not Assigned
22 Oxygen Sensor heating current
23 Short circuit to positive in Regeneration Switchover valve circuit
24 Not Assigned
25 Short circuit to positive in Start Valve circuit
26 Short circuit to positive in Shift Point Retard circuit
27 Data exchange fault between CIS-E Control Unit and EZL Ignition Control Unit
28 Loose contact in Coolant Temperature circuit
29 Difference in Coolant Temperatures between CIS-E Control Unit and EZL Ignition Control Unit
30 Not Assigned
31 Loose contact in Intake Air Temperature circuit
32 Not Assigned
33 Not Assigned
34 Faulty Coolant Temperature signal from EZL Ignition Control Unit
So Rick confirm which engine you have for certain - it may be you have the 3l with lots of grunt and not the 3.2l.
http://www.benzworld.org/forums/w124...ml#post5491653
1988 W124 Midnight Blue CE300 (224,000 kms)
Zender Body Kit (bumpers & skirts) / MB 'Facelift' front installed
LED Sports Mirrors / Eibach Pro Kit Suspension (lowered)
Ergon (Italian) E 17 inch wheels - 17x7.5""
Nexen 5000 235/45/17 Tyres
"Only two things are infinite, the universe & stupidity - and I'm not sure about the former." - Big 'AL' Einstein
stormtigers is offline
post #4 of 15 (permalink) Old 01-06-2013, 01:25 PM
cbc atl's Avatar
Date registered: Feb 2010
Vehicle: 89 300E; 00 E320
Quoted: 15 Post(s)
Models............................................ .............................................. Model Years
124.026 124.030 124.050 124.090 124.051 124.230 124.290 ...........1988-95
126.024 126.025 126.035 126.039 126.045 126.134 126.135 ...........1988-91
Connect wires of Scanner as follows:
Scanner........ Data Link Connector 8-pin
Yellow........... Socket 7
Black............. Socket 1
Red............... Battery (+)
FAULT CODE TABLE
DTC Readout........Possible Cause of Failure
1 No fault found
2 In car temperature sensor, short circuit
3 In car temperature sensor, open circuit
4 Outside temperature sensor, short circuit
5 Outside temperature sensor, open circuit
6 Evaporator temperature sensor, short circuit
7 Evaporator temperature sensor, open circuit
8 Heater core temperature sensor, short-circuit
9 Heater core sensor, open
12 Engine coolant temperature sensor, short circuit
13 Engine coolant temperature sensor, open circuit
30 Coolant pump, short circuit
31 Duo valve short circuit/open
33 A/C compressor control module short circuit
34 Auxiliary fan relay faulty
50 Switchover valve unit, faulty at between pins 5 and 8 (7 connections)
51 Switchover valve unit, faulty between pins 8 and 7 (7 connections)
52 Switchover valve unit, faulty between pins 8 and 3(7 connections)
54 Switchover valve unit, faulty between pins 8 and 4 (7 connections)
55 Switchover valve unit, faulty between pins 8 and 6(7 connections)
56 Switchover valve unit, faulty between pins 8 and 2(7 connections)
57 Switchover valve unit, faulty between pins 8 and 1(7 connections)
cbc atl is offline
post #5 of 15 (permalink) Old 01-06-2013, 03:00 PM Thread Starter
Rick Dean's Avatar
Thanks, helping out a friend, I'll get the engine number from him and post it. Car is from the UK.
post #6 of 15 (permalink) Old 01-06-2013, 04:39 PM Thread Starter
Rick Dean's Avatar
The vehicle was built in Sindelfingen Stutgart, Germany . The engine type is M104 980. The VIN No. Is WDB 1240611B 910830
Rick
post #7 of 15 (permalink) Old 01-06-2013, 06:22 PM
Quoted: 56 Post(s)
WDB 1240611B 910830 VIN REPORT
Wanted - ABS Fault codes for 1992 w124 CABRIOLET 16 pin connection.-wdb-1240611b-910830.jpg
ELEMENTARY MY DEAR WATSON = JUST AS I THOUGHT !
The mysterious M104.980 Engine with CFI system
Make sure you read the correct error code for that engine not the later 3.2 Litre.
Refer to my list posted earlier !
post #8 of 15 (permalink) Old 01-09-2013, 12:41 PM Thread Starter
Rick Dean's Avatar
Still stumped !!!!
Wonder why I can't find the codes for this car? Surly someone has them, I've looked and looked. Looking for the ABS codes.
Hello all, Looking for ABS fault codes for 1992 w124 300CE M104.980 Cabriolet 051 with 16 pin connection port. My code file listed below doesn't show it. Any help would be appreciated.
Thanks, Rick
post #9 of 15 (permalink) Old 01-09-2013, 02:29 PM
Quoted: 56 Post(s)
Thanks, Rick
Hello is this thing on ?
Rick -I posted the codes earlier !
5 Oxygen Sensor
6 Not Assigned
15 Not assigned
19 Not Assigned
20 Not Assigned
21 Not Assigned
24 Not Assigned
30 Not Assigned
32 Not Assigned
33 Not Assigned
What code are you missing ?
post #10 of 15 (permalink) Old 10-13-2013, 04:35 AM
Date registered: Aug 2013
Vehicle: 1999 C230 Kompressor. 1994 E220 before that (totalled)
Quoted: 21 Post(s)
Don't know if it is still needed... But Rick Dean, you will NOT find ABS fault codes in the 16-pin connector. The ABS on a W124 is a separate system, with its own Control Unit, and is not connected in any way with the main ECU. The only thing that relates ABS with the rest of the car's electrical/electronic system is the OVP.
What is the actual problem you're having with your friend's ABS?
Sicelo is offline
