my daughter says she hit a curb, i dont think she's telling the whole story! - Benzworld.org - Mercedes-Benz Discussion Forum
» Auto Insurance
» Featured Product
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Sedan Forums > W124 E,CE,D,TD Class
Old 12-03-2012, 11:11 AM   #1 (permalink)
david yeagley's Avatar
Date registered: Mar 2010
Vehicle: 1978 w123, 1984 w123, 1987 w124, 1990 W124, 1991 w124, 2001 W163
she says she hit a curb. her brother says she hit a curb and a mailbox! i think she hit something MUCH taller than a curb. i've never seen a strut assembly failure, so i thought the enthusiasts of the forum might like to see this. parts and labor = $370, includes both sides.
my daughter says she hit a curb, i dont think she's telling the whole story!-image.jpg
neags
david yeagley is offline   Reply With Quote
Old 12-03-2012, 11:23 AM   #2 (permalink)
Date registered: Jun 2007
Vehicle: '94 E320 T, '95 E320 T,'95 E300 DIESEL
The tower shock mounts crack over time, there are no struts on these cars. I bet that mount had many cracks in it and the curb was the perfect event that made it fail.
If you plan on keeping the car for a while, this would be ideal to replace the shocks and overhaul the suspension (i.e. ball joints) & steering components while everything is out.
You will need a alignment when everything is back together.
sbaert is offline   Reply With Quote
Old 12-03-2012, 01:16 PM   #3 (permalink)
semis1's Avatar
Date registered: Oct 2010
Vehicle: '91 C124 300CE, '06 W164 ML500, '00 BMW MCOUPE, '65 COBRA REPL.
With a failing shock mount, a curb only could do that damage. If it was also a mailbox, you would have body damage as well.
To change the shock mounts, is a fairly easy job if you have done suspension work before. If not, take it to an indie.
Both sides a must. For just shock mounts, alignment is not necessary. For the rest of the stuff mentioned above, necessary.
SAM
semis1 is offline   Reply With Quote
Old 12-03-2012, 01:46 PM   #4 (permalink)
yeah, there are white paint scuffs on the fender and the passenger side mirror. she definitely hit something and a curb. i think that she wandered off the side of the road and hit something more significant than a curb. maybe a drainage culvert or something more massive than a curb. you should see the wheel! i'm just glad she didn't drift into oncoming traffic. did i mention she was fiddling with her ipod?
anyway, as stated replacement of both shocks and the mounts, with alignment will be about $400. as sbeart noted the mounts were most likely cracked and brittle with age, and this occasion was the proverbial straw that broke the camels back. i will probably replace the shock mounts on mine as well, as they too are showing signs of cracking.
Old 12-03-2012, 02:40 PM   #5 (permalink)
RHW
RHW's Avatar
Vehicle: Silver S124 Estate and White A124 Cabriolet
"Daddy, I was driving along and heard a loud noise, the hood popped up, I lost control and hit a curb and brushed a fence"
A faulty mount could cause all of that.
Nonetheless, they do not have a truth mode at that age.
1994 S124 in 2012
RHW is offline   Reply With Quote
Old 12-03-2012, 03:50 PM   #6 (permalink)
LMFAO, or in the case of Lindsay Lohan: "I was just hanging out with friends and the next thing I knew I was in jail (again)!!! WHY do they keep harassing me???"
Can't wait for her porn debut "I did Herbie fully loaded"
BTW, did you find any Christmas lights hanging off the passenger mirror???
Back on a more serious note, since it looks like the damage is more than reported it think you might be dealing with a bent wheel and you will most likely need a alignment if not more. Definitely have the ball joints, A arms, tie rods and all other suspension & steering components checked for damage (i..e. bent/broken). This is a serious safety issue to whoever will be driving that car until it's been inspected and/or repaired.
Use Bilstein HD shocks for best ride and longevity, and get new bump stops for the shock shaft.
Old 12-03-2012, 04:38 PM   #7 (permalink)
Date registered: Sep 2012
Vehicle: 90 300TE 4-matic, 99 e320 4-matic, 97 S500, 57 Ford Ranchero, Sold: 95 s320, 82 380SL,71 3.5 cpe
The truth mode comes back in somewhere between 25 and 30 ;-)
sharples8 is offline   Reply With Quote
Old 12-03-2012, 04:41 PM   #8 (permalink)
Disley's Avatar
Date registered: Jul 2011
Vehicle: Mercedes Bus (public Transport)
Texting and keeping the car pointed in the right direction can be very hard.
Disley is offline   Reply With Quote
Old 12-03-2012, 04:55 PM   #9 (permalink)
. . . when the inheritance module/relay finally starts to work.
Old 12-03-2012, 11:04 PM   #10 (permalink)
ps2cho's Avatar
Date registered: Oct 2006
Vehicle: 1988 300TE, 2002 CLK320
Just a worn mount that was given one final "crack" at life and died doing it.
~$30/side in parts. Bilstein HD's. DO NOT BUY URO MOUNTS. DO NOT.....BUY....URO....PARTS If you or the mechanic does it, you better specify this or expect the same problem 10 miles down the road.
W124-Zone.com
1988 Pearl Grey Metallic Mercedes 300TE - 131k
2002 Silver CLK320 (Girlfriends) - 119k
FS: Brand New Lemfoerder Drag Link. PM Me
FS: Authentic AMG Gen I body kit (local AZ only). PM Me.
ps2cho is online now   Reply With Quote
Bookmarks
