1. Is the HVAC blower suppose to run softly/really low when starting vehicle? If not, whats going on?
2. Passenger headrest automatic up/down does not work. even manually moving it wont budge at all.
Drivers headrest auto retract goes up but not down. needs to be manually pushed down.
3. Check Lights Indicator always ON.
I've replaced my LH fog light bulb a few weeks ago and a couple days ago it already blew out.
Left tail light running light only the inner bulb lights up but all bulbs are new. Bulbs by the corner do not light up, but if I test the bulb on the other side, they work.
Cluster Tach/Clock light intermittent. Sometimes ON sometimes OFF.
HVAC left knob bulb out.
When depressing brakes all interior lights flicker. Center Dash/Door Switches/OHC Switches.
I've inspected and cleaned the ground wires by antenna, right tail light, under chassis ground by power steering gearbox, and the 3 ground spots by the front right shock tower.
I'm running out of ideas... My car is possessed...
