parting 91 TE - Page 2 - Benzworld.org - Mercedes-Benz Discussion Forum
» Auto Insurance
» Featured Product
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Sedan Forums > W124 E,CE,D,TD Class
Old 11-12-2012, 02:50 PM   #11 (permalink)
Date registered: Jul 2012
Vehicle: 1992 300D
hood
Where in Ohio? If you part it out I'd be interested in the hood. I'm in Michigan so I could come down and get it. Might be interested in the whole car if necessary. I have some extra wheels so i could car dolly it if needed.
Larry
bucketdad is offline   Reply With Quote
Old 11-12-2012, 06:54 PM   #12 (permalink)
Date registered: Mar 2009
Vehicle: '89 s124 300td
Send a message via Yahoo to arvsreyes
Hi, I'm interested in a few items. Please PM me your email address. Thanks
arvsreyes is offline   Reply With Quote
Old 11-12-2012, 07:36 PM   #13 (permalink)
meinpanzer's Avatar
Date registered: Aug 2010
Vehicle: 91 300E, 92 400E, 96 S420, 97 V10 Ford E350 to tow them home from time to time.
Originally Posted by david yeagley View Post
it's going to the junkyard because i am done trying to figure out it's problem!
the motor starts right up! once the temp reaches 80 it stumbles and loses idle. i've checked ovp, fuel pumps, acv, ecu, coil, plugs, wires, rotor, dist cap. temp sensors the list goe on and on. i strongly suspect that the wiring harness is baked, and at 220,000 mi. i figure i've got my moneys worth. also, i need room in the driveway!
I had that problem in an88 300E, it was the head gasket.
meinpanzer is offline   Reply With Quote
Old 11-13-2012, 06:32 AM   #14 (permalink)
david yeagley's Avatar
Date registered: Mar 2010
Vehicle: 1978 w123, 1984 w123, 1987 w124, 1990 W124, 1991 w124, 2001 W163
the shift knob and the all weather mats are not for sale. the car does have wheels, just not the ones pictured. the wheels on the car now are pretty beat up and the tires are spent.
here's what has been requested so far:
1. rear tail lights
2. hatch handle
3. climate control unit
4. hood
5. radio
another member suggested that i short out the temp sender and see if idle can be maintained. if it can, i may reconsider parting this vehicle. i will post result monday.
neags
david yeagley is offline   Reply With Quote
Old 11-20-2012, 08:27 AM   #15 (permalink)
update:
shorted the temp sender, car ran marginally better. i'm done with this car, so the part out is ON. i will contact all of you with prices next week, after the holiday. thanks to all-
Old 11-20-2012, 04:11 PM   #16 (permalink)
DP
DP's Avatar
Vehicle: 190E, 400E, 300TE
nooooooooooooo,
for $500 I will take it and even drive it all the way to Baltimore.
If you shorted the temp sender and this time it worked albeit rough, this means it's fixable!
Hey, I have a winter break after my finals on Dec 15 and I could show up, fix it and drive it away. unless you just want it fixed and then you will have to supply me with endless jugs of beer like in that picture.
DP is offline   Reply With Quote
Old 11-20-2012, 04:57 PM   #17 (permalink)
Savannahbenz's Avatar
Date registered: Mar 2007
Vehicle: 1987 300E, 1955 Plymouth Belvedere, 2005 Silverado 4x4
I had a similar problem that turned out to be the ECM. Big bucks if you go the new route but pretty reasonable if you go with a used or rebuilt unit. I see you also have a 90 model. If the ECMs are compatable, you may be able to temporarily swap in the 90 unit and see if the idle problem straightens out.
Savannahbenz is offline   Reply With Quote
Old 11-21-2012, 08:25 AM   #18 (permalink)
tried that! no joy.
Old 11-21-2012, 08:36 AM   #19 (permalink)
Modität!
Zeitgeist's Avatar
Date registered: Sep 2004
Vehicle: '87 300TD Sportline, '90 300D 2.5T + '94 100CSQ Avant + '89 Vanagon
Somebody has to nab this thing--that's a killer deal
Zeitgeist is offline   Reply With Quote
Old 11-21-2012, 01:49 PM   #20 (permalink)
Date registered: Nov 2012
Dave I sent you an email.
Thanks
Joe
joegt3cup is offline   Reply With Quote
Bookmarks
