Rust Mitigation - Page 3 - Mercedes-Benz Forum
post #21 of 36 (permalink) Old 11-17-2012, 05:43 PM Thread Starter
DP
DP's Avatar
Vehicle: 190E, 400E, SLK350
Quoted: 1038 Post(s)
CR, I used naval Jelly to remove the rust.
I had to go over the rust spots again today after i left them for a week to check for any rust I missed. There were a few spots that were coming back so it was a good thing that I didn't seal everything with bondo then paint. I am taking my time to make sure that I kill all of the rust in that area.
Tomorrow I think I have more quality time with the car and hopefully put some Bondo, sand it down, prime and then paint and blend.
DP is offline
post #22 of 36 (permalink) Old 11-17-2012, 07:37 PM
Date registered: Sep 2012
Vehicle: 97 S500, 99 e320 4-matic, 06 Q56, 57 Ranchero, Sold: 95 s320, 90 300TE 4-matic, 82 380SL, 71 3.5 cpe
POR-15 is outstanding for this sort of thing. I've used it on the bed of my 1957 Ranchero - it grabs the adjacent metal, dries rock hard and flat, and is completely impervious to further water damage.
sharples8 is offline
post #23 of 36 (permalink) Old 11-19-2012, 08:48 AM
Cancer_Researcher's Avatar
Date registered: Feb 2008
Vehicle: 03 Corvette Z06;08 GMC Acadia;84 230CE MANUAL Euro;12 Acura TL Tech Pkg; 02 Lexus LS430 Ultra Luxury
Quoted: 66 Post(s)
Thank you. I've got some superficial surface rust showing up in the roof that I really need to tackle. It started in the metal and came up and it has now caused the clear to explode. I gotta a lot of sanding to do and rust removal to do.
Question: After I kill all the rust, do I just spray some primer and paint and clear or do I need to apply some product to the bare metal before the primer?
Cancer_Researcher is offline
post #24 of 36 (permalink) Old 11-19-2012, 08:21 PM Thread Starter
DP
DP's Avatar
There is this spray on black paint that I found at PepBoys that turns rust into a paintable surface. I used that on the inside of the trunk and the batter tray and it did what it advertised.
DP is offline
post #25 of 36 (permalink) Old 11-20-2012, 05:17 PM Thread Starter
DP
DP's Avatar
It's moving along very well.
Bondo applied!
I sanded it down, applied again.
I then wet sanded and then applied some spot putty and let it dry overnight.
ID:	480126   Click image for larger version
ID:	480127   Click image for larger version
DP is offline
post #26 of 36 (permalink) Old 11-21-2012, 09:38 AM Thread Starter
DP
DP's Avatar
Update!
It's moving along. I just finished applying the second coat of primer after filling in any hairline stuff. I will be sanding the primer shortly after it's dry.
Photos:
first coat of primer
glazing putty
sanding
ID:	480292   Click image for larger version
ID:	480293   Click image for larger version
ID:	480294   Click image for larger version
DP is offline
post #27 of 36 (permalink) Old 11-24-2012, 03:17 PM Thread Starter
DP
DP's Avatar
Done!
It looks good for an amateur. Hopefully no more rust bubbles in that area.
Now I have another problem: after I reconnected the battery, the radio wants a code. I check my owner manual pouch and there is no such code anywhere
DP is offline
post #28 of 36 (permalink) Old 11-24-2012, 03:19 PM
Cruise Control
Zeitgeist's Avatar
Date registered: Sep 2004
Vehicle: '87 300TD/'90 300D/'94 Quattro/'89 Vanagon TDI/'01 EV Weekender VR6
Quoted: 1541 Post(s)
Take your title to the local dealer for the code
Zeitgeist is offline
post #29 of 36 (permalink) Old 11-24-2012, 07:21 PM
meinpanzer's Avatar
Date registered: Aug 2010
Vehicle: 92 400E, 95 S500,91 300TE practically stole it, 97 V10 Ford E350 to tow them home from time to time
Quoted: 2 Post(s)
Don't know if this will apply or if you have this radio.
ID:	481030   Click image for larger version
meinpanzer is offline
post #30 of 36 (permalink) Old 11-24-2012, 07:33 PM
93SoCal400E's Avatar
Date registered: Jul 2008
Vehicle: 2005 CLK500 w/23K !
Quoted: 37 Post(s)
Do some googling.
When this happened to me, I found a site or two that could figure out the code based on the SN of the radio.
Yes, it means that you have to yank the radio, but pretty easy with the tools or a credit card to cut up.
And you might even find that a previous kind soul wrote the code number on the unit itself.
93SoCal400E is offline
