Engine Removal Question - Benzworld.org - Mercedes-Benz Discussion Forum
» Auto Insurance
» Featured Product
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Sedan Forums > W124 E,CE,D,TD Class
Old 10-30-2012, 02:34 PM   #1 (permalink)
1992 300D's Avatar
Date registered: Oct 2012
Vehicle: 1992 300D, 1999 Ford F250 Superduty, 1946 Ford 1 1/2 Pickup
I just became a proud owner of a 1992 300D. I love it! The only problem is the motor has an issue and I have to pull the motor. Can I pull the motor without also pulling the transmissions? I can not unbolt the torque converter because I cant turn the motor over. If anyone has any insight on this I would love to hear. Thanks
1992 300D is offline   Reply With Quote
Old 10-30-2012, 02:58 PM   #2 (permalink)
Modität!
Zeitgeist's Avatar
Date registered: Sep 2004
Vehicle: '87 300TD Sportline, '90 300D 2.5T + '94 100CSQ Avant + '89 Vanagon
Pulling the engine with the TC still installed, may possibly distort the front pump on the transmission. If I had to separate the engine and transmission with the TC installed, I'd want to do this with both out of the car. When doing this in the car, the engine needs to be pulled at an angle, which will lead to the tweaking of the trans pump.
Zeitgeist is offline   Reply With Quote
Old 10-30-2012, 03:02 PM   #3 (permalink)
Date registered: Jun 2007
Vehicle: '94 E320 T, '95 E320 T,'95 E300 DIESEL
The best advice I can give is disconnect the flex disc @ the transmission and pull the whole engine & trans as an assembly with a cherrypicker.
sbaert is offline   Reply With Quote
Old 10-30-2012, 03:03 PM   #4 (permalink)
1992 300D's Avatar
Yea I think I will just pull the two together. A few more bolts and wire but I think it might help with the chance of creating more work down the the line. Also with the tranny out I can give it a good bath!
Do you think I should pull the oil cooler lines off of the housing our pull the entire oil cooler out with the motor?
Old 10-30-2012, 03:54 PM   #5 (permalink)
Disconnect the trans oil cooler lines just ahead of the crankshaft and leave the rest.
Replace the flex trans cooler lines if they look old or oil soaked.
With the engine out, be sure to replace both engine mounts and the trans mount. You'll never have easier access.
Old 10-30-2012, 05:53 PM   #6 (permalink)
1992 300D's Avatar
OK cool. But what about the engine oil cooler lines that come off of the filter housing.
Old 10-30-2012, 06:26 PM   #7 (permalink)
Modität!
Zeitgeist's Avatar
Just unscrew them at the filter housing and don't forget to unbolt the supporting bracket under the injection pump. Are you pulling the AC compressor too, or disconnecting the manifold?
Old 10-30-2012, 06:36 PM   #8 (permalink)
1992 300D's Avatar
OK. I just unbolted it from the motor and pulled to the side just like the power steering pump. I also just pulled the ALT. Off and straped it the core support. Does anyone know of a great place to get a FSM for my 92 300d because I will need torque specs and things like that?
Old 10-30-2012, 06:37 PM   #9 (permalink)
Modität!
Zeitgeist's Avatar
The FSM is linked in the DIY sticky at the top of the main 124 page. Everything you need is in there.
Old 10-30-2012, 06:39 PM   #10 (permalink)
1992 300D's Avatar
SWEET! I have been searching everywhere for one.
Bookmarks
