At what should the idle be,warmed up,in park,in gear, also with a/c on?
mine the 1990 300SE M103- park its at 700rpm,drive 550rpm,a/c on around 525rpm
did some work on the wife's car,seems to die at red light,idle to low
just replaced OVP,dist cap,wires good,tested and cleaned ICV,opens and closes like it should, did a propane test to the vacuum system,passed,cleaned fuel screen at fuel distributor ,duty cycle at 50%
car starts and drives,but feels to me like its lacking power,fuel pump and filter has 30k on them
I give it gas while driving and hesitates then takes off?
only thing left to do is adjust eha to distributor,its a used one from ebay, this low Idle stalling started after the eha was installed
what are your thoughts? Thanks
