W124 front suspension is DANGEROUS - Benzworld.org - Mercedes-Benz Discussion Forum
» Auto Insurance
» Featured Product
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Sedan Forums > W124 E,CE,D,TD Class
Closed Thread
Old 03-07-2012, 04:35 PM   #1 (permalink)
Date registered: Jan 2008
Vehicle: 1981 240d ,1991 300d, 1999 E300
I just had a lower ball joint pop loose while driving. Lucky me I was in the right lane.
Regulars here probably know about this problem..but I am still a bit shaken from the experience.
The car started to steer a bit stiff yesterday and I was going to take a look this weekend.
This type of design should be a recall since it is potentially very dangerous. Mercedes should demand that states report to them any older cars in service and have a warning sent to owners.
The front fender is damaged where the wheel hit it.
Tasma is offline
Old 03-07-2012, 04:53 PM   #2 (permalink)
augapfel's Avatar
Date registered: Jan 2006
Vehicle: Drivers: 88 260E, 88 300TE (2), Projects: 88 300TE, 91 300TE 4Matic, Parts: 88 300E (2), 88 300TE ++
Refresh my memory regarding Michigan's annual safety inspection program.
You know, the one where they put the car on a lift and check things like tie rod ends, balljoints, wheel bearings, shocks, brakes, etc.
Oh wait, Michigan has no annual safety inspection at all! Well then it's up to you, the operator, to make sure that the vehicle is in safe operating condition.
That kind of problem is well known in the 124 circles (and probably other chassis circles as well). It's why MBZ calls for a lower ball joint to be replaced immediately any time the vehicle is hoisted and a torn balljoint boot is found. The only time a torn boot doesn't condemn a balljoint is when the boot is torn while the vehicle is being serviced. Then you can buy the boot separately and go your merry way.
I worked in Michigan for years and was aghast at the vehicles I saw on the road. One winter day I was traveling on I94 to the airport and saw a Ford Maverick ahead of me and the driver was wearing a ski mask and snowmobile gloves. I wondereed what was going on and cautiously passed him.
I could see his legs and feet operating the pedals through gaping rustout areas in the driver's door! No joke.
My other favorite was the Monte Carlo I saw on Telegraph Road -- the car had no hood. Okay, well, alrighty then... Welcome to Michigan. Love the Party Stores!
augapfel is offline
Old 03-07-2012, 05:01 PM   #3 (permalink)
Mercedes Benz should know better than to design something that can fail this way. The engineers that designed my 240D had more common sense.
There probably isn't any excuse not to crawl under your car now and then and inspect everything and buy all new parts every few years but that is not something I have ever had to do.
There is also no excuse for designing a car suspension this way. They must have failed logical mechanical engineering 101.
Tasma is offline
Old 03-07-2012, 05:09 PM   #4 (permalink)
GHM
GHM's Avatar
Date registered: Jul 2005
Vehicle: "Gretchen" my 1986 300E 273000 km+
You should see the cars on the road here in Chicago, its all about revenue and forget about safety. The safety precautions on MB are second to none well maybe someone. The winters get pretty rough in Michigan and perhaps after years of sloshing around on salt ladened roads takes toll. Sometimes your personal safety in in your own hands.
An ounce of prevention is worth a pound of cure.
Remember the way things used to be, we can never get that time back,so make the best of the time you have now, Life is short!, Break a few rules! Forgive quickly! Love truly, Laugh uncontrollably ... Good times become good memories bad times become good lessons.
GHM is offline
Old 03-07-2012, 05:22 PM   #5 (permalink)
Date registered: Mar 2010
Vehicle: 1993 300E 2.8 W124.028 M104.942
Originally Posted by Tasma View Post
Mercedes Benz should know better than to design something that can fail this way....There is also no excuse for designing a car suspension this way. They must have failed logical mechanical engineering 101.
Hey, if it's that bad I'll give you $500 for the car and it won't trouble you anymore.
Had to replace my right ball joint, but the boot was torn and ball squeaking for months before I replaced it. If yours has been replaced before, it may not have been pressed in properly. Don't do it with a bench vise and socket... take it to a shop and have it pressed in with one of those 20ton thingys to make sure it seats properly.
thauber is offline
Old 03-07-2012, 05:28 PM   #6 (permalink)
If I had looked under the car and checked things this failure would not have shown unless prior knowledge of what to look for was used. As long as the spring in tensioning the ball you can't tell. Also from what I can see the boot was not torn. I suspect this car would have passed an inspection if done by someone that was not aware of problems with this model car.
Tasma is offline
Old 03-07-2012, 05:46 PM   #7 (permalink)
tuttebenne's Avatar
My 124 had 290,000 miles on the original ball joints when I replaced them last summer. One of them was making a horrible groaning noise. I think 290,000 miles (190,000 of which I put on the car driving as if it was a Maserati), is an indication of how well they did designing the suspension.
As for your 240D, they are great cars (I had a 300TDT) but not as easy to live with as a 300e. The vacuum lock diaphrams were problematic, steering boxes were prone to wear, windshield gaskets leaked water into the car and soaked the carpets, transmissions were bad - even after a rebuild (damn soft valve bodies!), and the 15 hole "Bundt" wheels were torture to keep clean. Not exactly an engineering masterpiece but a great car nonetheless.
'88 300E
'89 300E
'91 300TE 4matic
'93 400E
'93 500E
'77 308GTB
tuttebenne is offline
Old 03-07-2012, 06:01 PM   #8 (permalink)
TechGuru's Avatar
Date registered: Oct 2008
Vehicle: 1988 M-BENZ 300E ; 1991 FORD PROBE GT TURBO
Or buy your own:
20 Ton Shop Press - Hydraulic Shop Presses on Sale
and for the people too lazy to pump a pump lever:
Air / Hydraulic Shop Press w/ Oil Filter Crusher - 20 Ton
1988 Mercedes-Benz 300E (W124 M103 California Emissions/Controller)
: Laptop
TechGuru is offline
Old 03-07-2012, 06:36 PM   #9 (permalink)
Date registered: May 2011
Vehicle: 1990 300E
Tasma,
Glad to hear you came out of it alive and thanks for the heads up on the BJs. I'll put it on the top of my list.
1990 300E. Bone stock, 165xxx miles.
3.0L/chassis 103.983/ engine 124.030/ DOB 11/1989
1996 FZJ80
1997 FZJ80
1992 SVX
1967 MGB
alia176 is offline
Old 03-07-2012, 06:46 PM   #10 (permalink)
Savannahbenz's Avatar
Date registered: Mar 2007
Vehicle: 1987 300E, 1955 Plymouth Belvedere, 2005 Silverado 4x4
My 124 is 25 years old, 230,000,miles. Still on original front suspension members, well actually I'm changing them out right now. It didn't take a warning letter from MBUSA or NHTSA or the State of Georgia to tell me that the suspension parts were tired, it took common sense. If my car was a rust belt car, I would be suspicious of any undercarriage parts over 100,000mi because of the effects of road salt and potholes. My car has spent it's entire life in Georgia and Alabama so the undercar weathering is limited to a light coating of road grime that washes off with water. but after 25 years, it's a safe bet that parts are worn. It'll cost around $600 to do the front end, and will probably replace some parts that are still OK, but I'll know it should be good for another 200,000mi.
Do we wait until our Oil Level light comes on or our Oil Pressure Gauge to stop registering before we do an oil change? No we check the level weekly and change it at 3000-5000mi. or every 6 months. If we adopt the "drive it till it break"s mentality, our cars wouldn't last very long.
Savannahbenz is offline
Closed Thread
Bookmarks
W124 1995 E300 Diesel front suspension maintenance. Prerequisites for a long lasting cdw904 W124 E,CE,D,TD Class 0 02-10-2010 06:02 AM
1994 E-320 w124, front suspension L0WBNZ W124 E,CE,D,TD Class 4 12-28-2009 08:56 PM
W124 Front Suspension dan_the_barber W124 E,CE,D,TD Class 4 11-15-2009 01:31 PM
W124 Front Suspension - 124.128 vs. 124.09 jscottallen W124 E,CE,D,TD Class 2 09-24-2009 03:58 AM
W124 front suspension query... Cap'n Redbeard W124 E,CE,D,TD Class 3 08-22-2009 06:42 AM
