Seat covers? - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 02-08-2012, 11:17 PM Thread Starter
Date registered: Jul 2009
Vehicle: Used to drive 1995 C280, Used to drive 1987 300E (wrecked, sitting in garage)
Seat covers?
how do i pull out leather seats without the motors, just the covers and headrest off them? for the facelift w124s? or 1993.
jedi1241 is offline
post #2 of 5 (permalink) Old 02-10-2012, 02:11 PM
Date registered: Jul 2007
Quoted: 7 Post(s)
Seat cover removal
Your question is not clear to me.
Attached pdf may help you.
File Type: pdf Seat cushion drivers removal 91-180.pdf (1.57 MB, 93 views)
ds190 is offline
post #3 of 5 (permalink) Old 02-10-2012, 02:57 PM
stormtigers's Avatar
Date registered: Apr 2011
Vehicle: '88 "Zender" 300CE Coupe "BRUNHILDE"
Quoted: 61 Post(s)
The headrests need to raised to their fullest extension first.
Then the release button is just down from the top of the seat under the back cover. Search around with your fingers you should be able to find it. In mine it has actually left a little indentations in the material. You depress that button and out they come.
The seat backs are hard to get off.
At the very bottom there are two screws holding the seat back up onto the seat. The seat back then is supposed to slide down and off BUT they are an extremely tight fit. I have yet to get mine off as I am worried about breaking them. Unfortunately it is the only way to get into the hearest mechansim for raising/lowering.
If they have never been off and the car is (like mine) almost 25 years old I suspect they will be jammed tight and require a lot of grunting and groaning.
I did see a suggestion of getting someone to sit in the seat and opush back with their body which apparently eases the "join" to the back cover and makes it easier. Yet to try this
stormtigers is offline
post #4 of 5 (permalink) Old 02-10-2012, 08:22 PM Thread Starter
ah man what a pain in the butt.. my 87 300e, it wasn't that hard..
thanks for the pdf, it helped alot..
and thats what i meant basically, i need the seatbacks/bottom part
but i don't need the motors so yeah.. guess its time to scour the junkyards..
hey stormtigers how does the coupe button work exactly? is it controlled by a vacuum or something?
jedi1241 is offline
post #5 of 5 (permalink) Old 02-10-2012, 11:43 PM
Quoted: 61 Post(s)
no the button is just a release the lock on the headrest "inner" leg from the seat - all it does I believe is stop the headrest from extending too far up if it put by electronic means (i.e door switch)
Check out these two pictures also
http://www.benzworld.org/forums/w124...64#post2971890
1988 W124 Midnight Blue CE300 (224,000 kms)
Zender Body Kit (bumpers & skirts) / MB 'Facelift' front installed
LED Sports Mirrors / Eibach Pro Kit Suspension (lowered)
Ergon (Italian) E 17 inch wheels - 17x7.5""
Nexen 5000 235/45/17 Tyres
"Only two things are infinite, the universe & stupidity - and I'm not sure about the former." - Big 'AL' Einstein
    Seat Covers rdv R129 SL-Class 11 03-25-2010 04:51 AM
    Seat Covers Ajimoli W126 S,SE,SEC,SEL,SD,SDL Class 0 10-13-2009 01:50 PM
    Where to buy seat covers wombat888 R/C107 SL/SLC Class 18 06-13-2008 05:29 PM
    SLK Seat Covers ..:: AMG ::.. R170 SLK-Class 5 07-10-2007 01:57 AM
    Seat Covers hzd5 W164 M-Class 3 12-01-2006 08:02 AM
