300E won't turn over sometimes!!!! - Mercedes-Benz Forum
post #1 of 16 (permalink) Old 02-05-2012, 02:11 PM Thread Starter
Date registered: Sep 2011
Vehicle: W124 300E,W208 CLK320 Cab,W208 CLK430 Cab,W140 S500, 2003-2006 W211 E55 AMG on the way :)
I have a 92 300E that sometimes won't turn over. I have replaced the NSS & battery. I have searched forums over and over but can't find any thing similar. The starter sounds strong with no noise when it does crank and all wire look in good condition and attached to starter. Is there something that you all could think of that I'm missing. I may go out tomorrow and it crank fine but I feel uneasy letting my family go off in it when I'm away. Any help will be grateful.
bassfrad is offline
post #2 of 16 (permalink) Old 02-05-2012, 04:35 PM Thread Starter
I tested the X27 plug and can get engine to crank and run. Although when I tested the #2 from the switch it gets 12 volts any time the key is on. Also I have attempted to pull the entire key lock and can get it to slide out but there is not enough room to pull it completely out. Any advice, Im hoping I don't have to pull steering wheel and or column.
bassfrad is offline
post #3 of 16 (permalink) Old 02-07-2012, 09:17 AM Thread Starter
I sure do need a little help!! Great car won't run.
bassfrad is offline
post #4 of 16 (permalink) Old 02-07-2012, 09:31 AM
Indyz12's Avatar
Date registered: Jul 2009
Vehicle: 1989 300CE Blue-Black (M103-C124), 1993 500 SEL (M119-V140), 1985 500 SEC (M117-C126)
Send a message via Skype™ to Indyz12
Neutral Safety Switch
Try putting your car into N (assuming you have an Auto) and try again. The neutral safety switch thinks you are not parked and doesnt allow you to crank the engine sometimes.
let me know if it works!
Indyz12 is offline
post #5 of 16 (permalink) Old 02-07-2012, 09:35 AM Thread Starter
Does not work. I noticed that when I on plug the X27 the fuel pump comes on and I get 12 volts on female center pin when in position 2 or 3.
bassfrad is offline
post #6 of 16 (permalink) Old 02-07-2012, 09:41 AM
Indyz12's Avatar
Sorry i cant help, i should have read you already replaced the NSS.
I never got the hang of using the diagnostic port so im not much help.
Check all wiring going to the starter and battery alternator.
Indyz12 is offline
post #7 of 16 (permalink) Old 02-07-2012, 04:50 PM Thread Starter
All wires look good. I pulled the ignition switch and have good cont. from switch. I'm trying to remove the K38 relay but having a hard time getting it out. Any advice?
bassfrad is offline
post #8 of 16 (permalink) Old 02-08-2012, 06:55 AM
tuttebenne's Avatar
Date registered: Jul 2005
Quoted: 224 Post(s)
Have you verified the cable to the starter has good clean contact surfaces and the connection to the solenoid is solid? You might hook up a remote testing light to the solenoid so that when it doesn't start you can see if its because you have nothing at the solenoid or if its internal.
'89 300E
'90 300CE
'93 400E
'93 500E
'00 E320
'73 Alfa GTV
'77 308GTB
tuttebenne is online now
post #9 of 16 (permalink) Old 02-08-2012, 06:57 AM Thread Starter
It will crank using the X27 plug.
bassfrad is offline
post #10 of 16 (permalink) Old 02-08-2012, 09:10 AM
tuttebenne's Avatar
Quoted: 224 Post(s)
Alarm?
'89 300E
'90 300CE
'93 400E
'93 500E
'00 E320
'73 Alfa GTV
'77 308GTB
    1986 300E starter will not turn! No start! Yaoi-Wiccan W124 E,CE,D,TD Class 97 12-26-2016 04:09 AM
    MY90 300E left turn signal lens Rockfish W124 E,CE,D,TD Class 0 12-13-2011 07:29 PM
    Ignition key hard to turn on - 1993 300e Rick Dean W124 E,CE,D,TD Class 24 05-13-2010 01:26 PM
    WTB: 124 (300e, 260e) DS turn signal lens / side marker Eva89 For Sale/Wanted/Trade/Giveaway 0 05-25-2006 10:16 AM
    Hot start problem - won't turn over - '91 300E Guest (MBNZ) W124 E,CE,D,TD Class 1 06-12-2001 11:04 AM
