Check Engine Light - New Brakes - Benzworld.org - Mercedes-Benz Discussion Forum
» Auto Insurance
» Featured Product
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Sedan Forums > W124 E,CE,D,TD Class
Old 02-04-2012, 01:11 PM   #1 (permalink)
Date registered: Dec 2010
Vehicle: 1994 e320 Cabriolet
1994 e320 cab: 130k owned for 1 year, never a check engine light, wiring harness replaced by previous owner. Had front brakes replaced. After the first day noticed a chemical smell (likely spray used to clean rotors, etc.), second day smell still noticeable and then the check engine light came on. Is it possible fumes are effecting a sensor? I had a non-Mercedes that required left front fender be painted - paint fumes tripped the Check Engine Light.
Am I just fishing? Do not have a code reader - yet. Saw where I can reset by putting ignition to #2 position, pressing button (soon to be located). Any other suggestions?
hogan is offline   Reply With Quote
Old 02-04-2012, 01:42 PM   #2 (permalink)
lowesguy's Avatar
Date registered: Feb 2011
Vehicle: 1990 300se"white lighting" 1991 300E "Dieter " 1992 300E "2ZER"
Check codes,cel usually emission related,mine was coming on and wouldn't pass smog,replaced 02 sensor, still cel,replaced plugs cel went away ,passed smog! old plugs were platinum junk
John
lowesguy is online now   Reply With Quote
Old 02-04-2012, 02:43 PM   #3 (permalink)
Update - light off
Disconnected battery - light off (for now). Could not find 'button' listed in other areas of the forum for reset purposes. Does this car have one or too old/new? If yes, where's it located?
Old 02-05-2012, 03:19 AM   #4 (permalink)
Jayare's Avatar
Date registered: Jun 2005
Vehicle: 86 190E 2.3L 16V, 90 300CE (sold), 93 400E, 93 190E 2.6L "Limited Edition" #487 of 700 made, 98 S500
Hogan,
The code reader for your car is built in and located on the compartment wall, to the inside of the battery. Read all of this link - http://www.benzworld.org/forums/w124...eader+location
Good Luck
Jayare
Jayare is offline   Reply With Quote
Bookmarks
SBC.. BRAKES .. and check oil light pineapplegti W211 E-Class 9 10-20-2011 12:29 PM
How did My 300E Pass the Smog check with Check engine light? cdvyas W124 E,CE,D,TD Class 1 03-09-2011 07:43 PM
How to check code for check engine light 94 E320 W124 Synd W124 E,CE,D,TD Class 1 05-24-2007 02:37 PM
check engine light on; brakes squeak; keys problem essence W163 M-Class 5 07-15-2005 06:51 PM
check engine light on; brakes squeak; keys problem essence The Discount Tire Direct Tire, Wheel, Brake & Suspension 0 07-08-2005 09:02 PM
Powered by vBulletin® Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
