buying a new wiring harness - 93 400E - Page 3 - Mercedes-Benz Forum
post #21 of 33 (permalink) Old 03-12-2012, 11:34 AM
Date registered: Feb 2010
Vehicle: 93 300E 2.8
Anyone know the parts number for the lower harness for a 93 300E 2.8? I know mine needs to be replaced (insulation completely gone in some areas.) My engine harness was replaced by a PO.
GermanCarGeorge is offline
post #22 of 33 (permalink) Old 03-12-2012, 01:01 PM
Date registered: Jan 2012
Vehicle: 90 300TE, 93 400E, 01 E430
Seems like I replaced both the upper main & lower right harness when I put the new motor into Rhonda's 400E, but don't remember paying that much for either part. Maybe $400 range for both harnesses. When I get my records back from my CPA office I'll look maybe we can do better pricing for those that need the harnesses. Some of the stuff came from WorldPac some from SSF. We'll see they were combined into a receipt with parts for all three cars. I'll let you know.
Dcharlesjr is offline
post #23 of 33 (permalink) Old 03-12-2012, 01:11 PM
Date registered: Feb 2012
Vehicle: 1991 300E 2.6
Originally Posted by 93SoCal400E View Post
If you are having weird engine electrical gremlins and don't know if your harness is from the "self destruction design" period, find out. If you have an original one from the bad years, get it replaced.
When was the "self destruction design" period? What were the bad years?
Camman595 is offline
post #24 of 33 (permalink) Old 03-12-2012, 01:35 PM
sbaert's Avatar
Date registered: Jun 2007
Vehicle: '95 E300 DIESEL, '91 600SEL, '92 600SEL
Quoted: 992 Post(s)
MY92-MY97 were the bad years. This applies to anything MB produced during this period, whether it be a lowly C220 to a fully optioned S600.
I once came a across a very early '92 500E, built in late 1991 that also had the bad wiring.
sbaert is online now
post #25 of 33 (permalink) Old 03-12-2012, 05:13 PM
Date registered: Jul 2004
Quoted: 337 Post(s)
That isn't true, none of the CIS cars were affected, and none of the 97s were affected, and many of the 96s weren't.
Part number for the lower harness for a 2.8 is 124 540 42 30, lists for $137, commonly discounted.
deanyel is offline
post #26 of 33 (permalink) Old 03-12-2012, 10:51 PM
Thanks, I scoured the EPC looking for that!
post #27 of 33 (permalink) Old 05-24-2013, 03:41 PM
Premium Member
Date registered: Sep 2006
Vehicle: 1989 560SEC AMG Euro / 1997 S500 / 1991 500 SL Euro / 1991 500 SL Japan
Quoted: 9 Post(s)
Premium Member
CHASSIS: WDBEA34E2NB711347
ENGINE: 119975 12 001911
TRANSMISSION: 722354 03 676639
BODY: 00774
ORDER NUMBER: 0170159 922
I hate to resurrect an old thread, but I find myself in the same boat with my 1992 400E with ASR. I recently had the ASR actuator and wiring rebuilt replaced with updated parts.
The origina engine wiring harness on my car is on it's last legs due to the infamous failing insulation and needs to be replaced.
The number on the harness I have now is 124 543 88 32
My questions are:
- I was also told there is a smaller sub-harness for the MAF, CPS, etc that would need to be replaced as well which carries another part number that is currently unknown to me. Any help?
- Has 124 543 88 32 been superseded? I see 124 440 19 06 also listed as a compatible harness. I also see 124 543 77 27 as a possible harness for ASR cars?
Any help would be greatly appreciated!
- Steve
1989 560SEC AMG Euro / 1990 300SE Euro / 1991 500SL Japan / 1997 S500 USA
cyberdyne is offline
post #28 of 33 (permalink) Old 05-25-2013, 04:06 AM
Jayare's Avatar
Date registered: Jun 2005
Vehicle: 86 190E 2.3L 16V, 93 400E, 95 320TE, 95 E320, 98 S500
Quoted: 689 Post(s)
Use your VIN to obtain the correct harness. There isn't a separate harness for the throttle actuator. It is part of the throttle actuator. The same soy based doomed material is used inside the actuator etc. The easy re-build harness is the lower one. Starter, alternator, oil level and oil pressure.
Jayare
Jayare is offline
post #29 of 33 (permalink) Old 05-26-2013, 10:00 PM
93SoCal400E's Avatar
Date registered: Jul 2008
Vehicle: 2005 CLK500 w/23K !
Quoted: 39 Post(s)
The crappy dead harness I yanked was 124 543 8832 and the newer built replacement I got on Ebay for like $250 was 124 440 1906 and matched perfectly. Mine was a '93 and did NOT have ASR.
93SoCal400E is offline
post #30 of 33 (permalink) Old 05-26-2013, 10:24 PM
Premium Member
Quoted: 9 Post(s)
Premium Member
Thanks!! That's a big help.
I am still trying to confirm by VIN to make 100% sure I get the correct harness(es?).
The two Russian EPC sites both list 124 543 88 32 as the harness for up to MY 1992 cars, and list 124 440 1906 as starting MY 1993 based on my VIN.
124 543 88 32 is in my car right now and I found a seller who lists 124 440 1906 as the updated Delphi-made replacement for the 400E so I might jump on it if I can confirm it is the proper unit.
- Steve
Wiring Harness Symptoms? '93 400E 93SoCal400E W124 E,CE,D,TD Class 13 12-15-2009 04:55 PM
1992 400E same wiring harness as 400SE? Bob-e W124 E,CE,D,TD Class 4 09-28-2009 11:31 AM
400E Engine Wiring Harness Jayare W124 E,CE,D,TD Class 3 06-17-2008 03:14 PM
400E lower wiring harness Rahray W124 E,CE,D,TD Class 5 02-08-2008 10:15 AM
400E wiring harness Rahray W124 E,CE,D,TD Class 2 07-10-2006 10:41 PM
