Oil Pressure Sensor Failed again within a week - Mercedes-Benz Forum
post #1 of 8 (permalink) Old 09-24-2011, 01:42 AM Thread Starter
Yai4485's Avatar
Date registered: Jun 2011
Vehicle: W124 E220 Year 1995
Please give an advise.
My car W124 E220 1995 Engine M111. Last week I have noticed that the Oil pressure gauge was failure when I switch on the key at position 2 before start the engine the oil gauge needle is swing and pointed at 3 bar and still there without a move until I switch off the key. I decided to change a new OEM Oil pressure sensor see pic. All go fine when I switch on position 2 the needle still at 0 bar as soon as I start the engine the needle clime up to 3 and when the engine temp is around 90 it will swing from 3 to 2 and 3 depend on I press the pedal. That is what I think it's normal. Today when I switch on at position 2 before I start the engine the needle is sprung up to 3 bar and still there until switch off..Oh...what going on.? Please help what going to check.?
ID:	399334   Click image for larger version
ID:	399335   Click image for larger version
No Matter What happen ! Keep Breathing...!
Yai4485 is offline
post #2 of 8 (permalink) Old 09-24-2011, 02:33 AM
~BANNED~
Date registered: Feb 2009
Vehicle: 1993 400E
Quoted: 419 Post(s)
Has the lower engine harness been changed?
That will cause the problem your describing.
Clarkz71 is offline
post #3 of 8 (permalink) Old 09-24-2011, 04:12 AM Thread Starter
Yai4485's Avatar
Thanks a lot Clark.
I haven't change it before and I think it's right time.
I have suspicious the wires of oil pressure sensor but didn't think for
the whole lower engine harness. Can it replace by DIY?
Yai4485 is offline
post #4 of 8 (permalink) Old 09-24-2011, 04:15 AM Thread Starter
Yai4485's Avatar
Dear Clark,
Would you please also advise me for this problem.?
Thank a lot.
http://www.benzworld.org/forums/w124...e220-m111.html
Yai4485 is offline
post #5 of 8 (permalink) Old 09-24-2011, 07:20 AM
~BANNED~
Vehicle: 1993 400E
Quoted: 419 Post(s)
Originally Posted by Yai4485 View Post
Thanks a lot Clark.
Tou can do it yourself if you do other work on your car besides oil changes.
Labor at a shop shoudn't be more then 2 hours though.
If your not comfortable with electrical work you may want a shop to do it.
Clarkz71 is offline
post #6 of 8 (permalink) Old 09-25-2011, 05:51 PM
jhodg5ck's Avatar
Date registered: Sep 2002
Vehicle: Depends on the day!
Quoted: 14 Post(s)
Send a message via AIM to jhodg5ck
is that a VDO or crappy chinese knock off?
Blue Ridge Mercedes/AMG East
Jonathan Hodgman
http://www.blueridgemb.com/
Enthusiast Service, Restoration & Tuning.
Authorized RENNtech Dealer & Installer
Follow Us on Facebook!
Located in the Atlanta area
87 Hammer Wagon 6.0L 32V
87 Hammer 6.0L 32V
86 560SEL AMG 6.0 32V
etc....
Mercedes Repair Atlanta
jhodg5ck is offline
post #7 of 8 (permalink) Old 09-26-2011, 10:11 PM
Date registered: Oct 2008
Vehicle: '89 420SEL, '93 300E and '07 Hyu Santa Fe
Quoted: 11 Post(s)
my lower engine harness is original and this is happening with my car.
I took all old cables off and used electrical tape to fix harness as much as i can before i left us. Once i go back i have to continue doing this.
No use throwing parts untill you change this harness.
Good thing my main harness was changed long ago.
'93 300E 2.8, Green (205K...)
'07 Santa Fe SE, Natural khaki (95K..)
'04 S500 (122k..)
'89 420SEL, Diamond Blue (154K..) Retired
'08 kawi 250R, Red (10K..) (Sold)
MBCarGuy007 is offline
post #8 of 8 (permalink) Old 09-27-2011, 01:35 AM Thread Starter
Yai4485's Avatar
Arrow
Thanks for advise.
Yesterday I discussed with Benz Electrician he supposed the plug was too old.
I checked it myself and found that the oil sensor plug was cracked and brittle
I pushed it a bit more tighter and some part of its cover shell was broken off
but the oil pressure gauge returns to normal function. I think I should buy new sensor plug and make a new wire and let see what happen.
Yai4485 is offline
    Oil Pressure Sender Unit Failed Prochambers W126 S,SE,SEC,SEL,SD,SDL Class 10 08-14-2011 07:43 AM
    Oil Pressure Gauge Failed! Benzy B W124 E,CE,D,TD Class 15 07-14-2009 10:09 PM
    W208 - Bypass Failed Oil Sensor timothy_ware C208/A208 CLK-Class 4 05-11-2009 12:40 PM
    Oxygen Sensor - Failed? bluemoco W210 E-Class 18 09-13-2008 02:19 PM
    Near disaster when Fuel Pressure Regulator failed in S320 CDI Nigel555 General Mercedes-Benz 4 08-04-2004 01:51 PM
