'92 400E, Radiator Issues - Mercedes-Benz Forum
post #1 of 7 (permalink) Old 09-07-2011, 08:41 AM Thread Starter
xBrock's Avatar
Date registered: Sep 2011
Vehicle: '92 400E
Send a message via Skype™ to xBrock
Exclamation '92 400E, Radiator Issues
yesterday my car [1992 400E] broke down, over heated and had no coolant in it. i managed to get it home with some help, and i refilled it with coolant. i drove it around last night and it was fine. this morning before i left for school i checked and there was no wet spots so i assumed no leaks. but on my way to school the warning light for low coolant came on. i stopped and checked, everything seemed fine, went on to school. this is unsettling though because i don't want to drive it around if there's a issue. i get out of school soon and i will check for wet spots, pop the hood and look around before i go anywhere. does anyone have any suggestions, maybe a leak? i'm not to smart with cars but would me living in Texas with the heat make a difference? Thanks!
xBrock is offline
post #2 of 7 (permalink) Old 09-07-2011, 08:49 AM
sbaert's Avatar
Date registered: Jun 2007
Vehicle: '95 E300 DIESEL, '91 600SEL, '92 600SEL
Quoted: 1016 Post(s)
First check visually that you do indeed have coolant, which it appears you've already done. Only use genuine MB coolant or Zerex G-5 mixed 50/50 with distilled water. Using anything else is asking for trouble.
If the low coolant light still comes on despite having enough coolant in the reservoir, you may have a bad float (the sensor in the reservoir). Also make sure your radiator cap is good.
If you are unsure of the age/condition of the reservoir and cap, replace the whole assembly (reservoir, tank & float).
Most importantly, you need to find out why your car overheated (bad thermostat, bad fan clutch, bad electric fan, etc.).
sbaert is offline
post #3 of 7 (permalink) Old 09-07-2011, 08:51 AM Thread Starter
xBrock's Avatar
Vehicle: '92 400E
Originally Posted by sbaert View Post
First check visually that you do indeed have coolant, which it appears you've already done. Only used genuine MB coolant or Zerex G-5 mixed 50/50 with distilled water. Using anything else is asking for trouble.
If you are unsure of the age/condition of the reservoir, replace the whole assembly (reservoir, tank & float).
Thanks, I will check that.
although i put what coolant i had which i believe was some generic coolant. i will run over to napa and get some MB coolant.
xBrock is offline
post #4 of 7 (permalink) Old 09-07-2011, 11:50 AM
macdrone's Avatar
Date registered: Nov 2006
Vehicle: 1993 400E 23100 miles "Gunter", 1999 ML320 200000 miles "Fizgig"
Your issue is most likely a pressure loss issue, then once air was introduced it spouted out the rest. Always check the easy stuff first. Almost fill system then run with radiator cap off and burp the system to get air out of the block and pump area. Then put cap back on expansion tank and it will vent some fluid as the seam is about the "fill" line for expansion. Know that the overflow tank is in the fender well where you cant see, so water will spill out of it when the cap pops to let fluid out. Thats why you dont see a steaming mess when your out of fluid like in american cars. Usually the pressure leak is a hairline crack in the expansion tank where the small line connects to the radiator or the radiator line to the expansion tank (from my experience) If you have no leaks do a search on Aux fans for troubleshooting, and viscous fan troubleshooting, if those operate then thermostat and water pump. I found with mine it was all leak issue. Even when my aux fans froze up with no pressure loss in my cooling system my car never over heated.
Good luck.
macdrone is offline
post #5 of 7 (permalink) Old 09-07-2011, 04:47 PM Thread Starter
xBrock's Avatar
Vehicle: '92 400E
Good luck.
thanks for all your input!
xBrock is offline
post #6 of 7 (permalink) Old 09-07-2011, 05:24 PM
Date registered: Mar 2010
Vehicle: 2005 E320 W211
Check your oil and make sure there isn't any coolant getting mixed into it. If you don't park on clean concrete, try putting a peice of cardboard under the engine and cooling parts overnight. As hot as it is there, it may be drying enough to not see on a dirty surface, but it will stain the cardboard even if it dries.
Try taking it for a short drive to get it up to temp after you top off the coolant to the seam on the tank, and then park it with the engine still running and trace the overflow hose mac is talking about to see if there is anything coming out the end or if it is wet. Also wiggles the tank a little to see if you hear a hissing noise to make a microcrack more apparent.
If all that checks out, and you still lose coolant, check your plugs for signs of water inside the cylinders.
Hope you get it tracked down.
thauber is offline
post #7 of 7 (permalink) Old 09-07-2011, 07:58 PM Thread Starter
xBrock's Avatar
Vehicle: '92 400E
Thanks everyone for all of your input. I have done all of these things.
I appreciate all the help, i'm new to the automotive world but i want to know everything i can and i would like to keep my car in best shape possible.
I haven't had any issues after this morning that one time. I shall keep you posted over the next few days, again thanks!
xBrock is offline
1994 400E transmission issues...Help? RckyMtnBenz W124 E,CE,D,TD Class 9 03-22-2011 02:50 PM
radiator (used) for 400E, 500E, E420 hanno2s@verizon.net For Sale/Wanted/Trade/Giveaway 0 07-22-2010 03:44 PM
400e died in driveway issues macdrone W124 E,CE,D,TD Class 7 03-23-2008 10:21 AM
WTF RADIATOR ISSUES :( omairtheman1 W124 E,CE,D,TD Class 19 10-31-2007 11:02 AM
400E Steering Issues need help/advice macdrone W124 E,CE,D,TD Class 8 03-08-2007 12:07 AM
