diesel excessive black smoke - Mercedes-Benz Forum
post #1 of 10 (permalink) Old 04-23-2011, 06:21 PM Thread Starter
Date registered: Jan 2011
Vehicle: 1993 300D 2.5, 2003 BMW 330i, 82 Mercedes 380SEC,86 Jaguar XJ6, 97 Toyota 4x4, 97 BMW 318i
I have a 1992 330d 2.6 turbo. Getting quite a bit of black smoke at idle and accleration. I have searched several threads and one reply was:
"he switchover valve for fuel enrichment compensator was inoperativehave searched several threads and someone identified the excessive black smoke as "
Can anyone tell me where this is and other possible causes of the smoke.
Thanks
mako224 is offline
post #2 of 10 (permalink) Old 04-23-2011, 06:53 PM
babymog's Avatar
Date registered: Apr 2011
Vehicle: 2015 ML250 Bluetec
Quoted: 4 Post(s)
Switchover valve can not cause smoke.
Black smoke is excessive fuel, if you're getting it at idle you likely have an injection problem severe enough to not drive the car (can overheat the pistons etc.).
Try to isolate the cylinder by loosening the injection lines to the injectors one at a time. The one that makes the smoke stop or lessen significantly is a bad injector or the bad element/DV on the pump. Pull the bad injector, switch it with another, see if the problem follows the injector (bad injector) or stays on that cylinder (bad IP).
If it is more than one cylinder, it is possibly a problem with the intake, a plugged air filter (mouse nest?) or intake (probably should check this first), which will not let the engine have much if any power.
- Jeff
babymog is offline
post #3 of 10 (permalink) Old 04-30-2011, 11:40 AM Thread Starter
I ran two injector purgers, no change. Replaced # 3 injector it looked wet. Still have black smoke at idle. Drove for an hour and visually checked the injectors and the new #3 injector is wet. Loosened the supply to each injector individually and no change except when each was loosned the engine ran on 4 cylinders.
The car idles / less smoke since thew injector #3 replacement; however, seems to idle clear for 20 or 30 sec and drops a couple of rmps and chugs black smoke for about the same time. In gear at idle is when the most black smoke is seen ... cars behind me at a light will keep about a car length.
The car runs fine ... idles ok just lots of black smoke at idle. Averges 34 mpg on the highway.
Any additional suggestions.
mako224 is offline
post #4 of 10 (permalink) Old 05-01-2011, 11:39 AM
Date registered: Jul 2008
The wetness on the injector sounds like it's just the return line leaking. If these injectors are like any other IDI there is a copper washer that must be replaced when you pull an injector out otherwise you'll toast the reinstalled injector. Hard to say what exactly your problem is but for some reason your fuel isn't being burnt. Sounds like bad injectors or a timing problem with the pump to me. Mine produces alot of smoke too, but only a little bit during idle and alot if I floor it. While cruising it's not that much, i get about 35 MPG.
1992 300D - 178,000 miles.
yaric is offline
post #5 of 10 (permalink) Old 05-01-2011, 11:56 AM Thread Starter
I didn't see a copper washer; however, there was a heat shield washer that fits concave on the bottom of the injector. It's idling fine for 14 sec and then drops a couple hundred rpms and smokes for 14 sec, bact to normal idle and no smoke.
This went on for 15 minutes. When I put the car in gear with the brake on it smokes even more.
Check all vaccum lines and they look ok, pulled the leed off the MAF and it stumbles a bit but returns to idle.
Something else odd .. I can hold the throttle open at about 1300 rpm and the engine will eventually, 20 sec or so, drop down to almost idle and in 20 sec or so climb back up to 1300 rpm. Is it normal to have the inside of the intake coated with a black gook? Mine has quite a bit.
I have 4 more new injectors that will be installed tomorrow. If this doesn't work .... i'm lost. Any other suggestions to check are much welcome.
mako224 is offline
post #6 of 10 (permalink) Old 05-02-2011, 06:05 AM
winmutt's Avatar
Date registered: Sep 2005
Vehicle: money pits of various forms
Quoted: 95 Post(s)
Send a message via AIM to winmutt Send a message via MSN to winmutt
Is this a new car to you? I dont see it listed in your CP. Could be the ALDA is all the way out?
winmutt is offline
post #7 of 10 (permalink) Old 08-13-2012, 10:27 AM
Date registered: Aug 2012
Vehicle: 74 450 SEL, 78 300D, 99 Ford 7.3 turbo
B]BLACK SMOKE IS CAUSED BY 1. EXCESSIVE FUEL, 2. INSUFFICIENT OXYGEN, AND 3. LATE TIMING.[/B] All these can be caused by blocking of orifices in bottom of precombustion chambers (PC's)! How does a home mechanic comply with Equipment Repair Notices from the Highway Patrol? Take the PC's out, drill out holes (if clogged) with .110" (#35) drill bit, reinstall for a most dramatic improvement. I have now done this to 2 300D's, one turbo and mine, NA. Results were dramatic! I now know of 4-300D engines with less than 300k miles that were junked for loss of power and excessive smoke. One was rebuilt, and the only real problem noticed was, you guessed it, nearly completely blocked PC orifices. Vehicle histories indicate preponderance of in-town slow speed driving for many years. I'll bet the orifice cleaning procedure is well known at the MB dealerships: Very little cost for great improvement and high repair bills! This repair does not require new parts, other than PC gaskets and injector heat shields ($30 total), if you want to be picky. Get the tools and do it yourself! The job takes 2-4 hours, depending on you level of ineptitude.
allsafe is offline
post #8 of 10 (permalink) Old 08-13-2012, 10:52 AM
sbaert's Avatar
Date registered: Jun 2007
Vehicle: '95 E300 DIESEL, '91 600SEL, '92 600SEL
Quoted: 956 Post(s)
What is the OM engine model#???
US spec W124 diesels only came with 3 possible engines. The OM603, OM602 and the twin cam OM606. The OM603 & 606 were 3 liter 6 cylinder motors while the OM602 was a 2.5L 5 cylinder.
All the cars were labeled as 300 Diesels. Never heard of a 330D with a 2.6 turbo.
sbaert is offline
post #9 of 10 (permalink) Old 08-13-2012, 12:50 PM
winmutt's Avatar
Quoted: 95 Post(s)
He means 300D with 2.5 turbo I am assuming. I didn't think about this last time but the idle flap could be to blame.
winmutt is offline
post #10 of 10 (permalink) Old 05-24-2013, 11:22 PM
NKB
Date registered: May 2013
Hey allsafe, NKB of Prescott here. How's that rebuild running?
Sorry for not updating my broken oil pump (I'm a little 'cyber-challenged' with this forum.
NEW PROBLEM: Since replacing pump (new one), and filling the new pan with new oil, I now have a 'black smoke'/hard starting/total lost of power problem. My 300D was running STRONG before I hit that big rock. She never overheated, I have max oil pressure, and my local friend/diesel mechanic and I checked the timing marks and the chain was right on the money (did not jump a tooth). My injectors are new (though I found no copper washers) ENGINE FIRES RIGHT OFF ON ABIT OF ETHER, then runs rough and weak with lots of smoke.
QUESTION: What's the likelihood of injector pump or PC chamber problems occurring, concurrent with a busted oil pump? Maybe check flow from tank (rough road shook some crud up)? Check/ replace fuel filters (remember I have been running Veg-oil with a blend of diesel SUCESSFULLY for five years)? Drill out the PC's as you suggest?
Any ideas? Thanks for the consideration. NKB
NKB is offline
    Excessive Blue Smoke from Tailpipe Martin2009 General Mercedes-Benz 2 08-07-2012 07:18 PM
    Help: excessive fuel. Black smoke. High idle w124202 W126 S,SE,SEC,SEL,SD,SDL Class 8 08-03-2010 05:47 PM
    407 d has excessive white smoke PhilT General Mercedes-Benz 0 05-28-2009 02:35 AM
    Bad Black smoke and Knocking after filling up with suspected contaminated diesel vegioilpokertour General Mercedes-Benz 9 10-22-2008 10:33 AM
    Black Smoke from diesel neemhakim W123 E,CE,D,CD,TD,TE Class 12 08-31-2007 05:18 PM
