1994 E320 Wiring Harness Symptoms - Mercedes-Benz Forum
post #1 of 22 (permalink) Old 04-20-2011, 08:10 PM Thread Starter
Goodchild's Avatar
Date registered: Feb 2008
Vehicle: 1994 S500 LWB, 1970 220D, 1994 E320, 1992 JAGUAR XJ6
Hey Guys,
I have found this forum to be very useful and as such I wanted to contribute a little based on my experience.
On my 94 E320 109kmiles, i had a rough idle that wouldnt go away and the car would sometimes bog down under power. I had a hint that the harness was bad but thought it wasnt so bad close to the engine.... Turns out i was WRONG! Eventually the car wouldn't start and then I towed it back to "Uncle Benz Hospital" better know as my garage then i proceedes to test for spark and then realized that 2 out of 3 ignition coils were not firing...so with a blade tore of the outer insulation of the coil connectors and bam! crumbs like bread- insulation of the harness. what i had seen elsewhere on the engine wiring harness was true.
Moral of the story:
When it comes to Mercedes-Benz, cutting corners is absolutely futile... If you see its bad change it! As an aspiring Benz tech, I was happy to discover that the harness could crumble to the point where the car wouldn't start anymore. I wish everyone on theW124 FORUM the best in diagnosis!!
Goodchild is offline
post #2 of 22 (permalink) Old 04-20-2011, 09:49 PM
sbaert's Avatar
Date registered: Jun 2007
Vehicle: '95 E300 DIESEL, '91 600SEL, '92 600SEL
Quoted: 927 Post(s)
Don't forget the ETA (electronic throttle actuator). It suffers from the same wiring symptoms and will cause electrical nightmares until it's been replaced. These later W124s are almost impossible to diagnose electrically until the harness & ETA have been replaced.
The ETA is VIN specific, depending if your has ASR or not.
sbaert is offline
post #3 of 22 (permalink) Old 07-02-2011, 10:29 PM
Date registered: Jun 2011
Vehicle: 1994 Mercedes E320
What is the most prominant place for the harness to fail? Can this section be repaired and wires re taped or enclosed in a wire loom? What information would be needed to ensure compatibility?
Thanks for any information
senikc is offline
post #4 of 22 (permalink) Old 07-02-2011, 10:56 PM
macdrone's Avatar
Date registered: Nov 2006
Vehicle: 1993 400E 23100 miles "Gunter", 1999 ML320 200000 miles "Fizgig"
Once it goes bad you would have to re wrap all the wires. They all cooked at the same rate. They will degrade from firewal to ungine, and there is a lower harness but its less of an issue due to less wires.
When I first waited to get mine i bought a sppool of wire and soldered it all together 1 wire at a time and did it in about 4 hours.
Worked great for the 2 weeks I used it.
If you see any issues on any of the wires you might as well take it out and do them all. It will be just a matter of time.
macdrone is offline
post #5 of 22 (permalink) Old 09-23-2015, 04:53 PM
Date registered: Sep 2015
So I am looking to buy a 1994 E320. Is there trick to determining if the wire harness is defective? Other than visually looking? Is there an ideal part of the harness to inspect?
MediaGiant is offline
post #6 of 22 (permalink) Old 09-23-2015, 05:13 PM
NobleTruths's Avatar
Date registered: Oct 2013
Vehicle: 1995 E320 Cabriolet x 2
Location: If you live north of the Texas Red River, you are a damn yankee!
Quoted: 502 Post(s)
Look behind the battery backsplash. On the driver's side of the connector plug area, look for a white tag attached to a large wire bundle with the name "Delphi" on it. No tag = original eco-junk harness. Take pictures to post if you are not sure.
This is not the best picture, but you can see it just above the corner of the battery:
Can also make it out here, too:
I have several wiring harnesses (E300/320 and E400/420), ETA's, side/tail/headlights and trim for sale. I can also get requested parts from local JYs. PM me.
NobleTruths is offline
post #7 of 22 (permalink) Old 09-23-2015, 05:22 PM
Thanks for the response, very helpful. So battery is on the passenger side, correct?
If it is the original, what would harness cost? are there used available?
post #8 of 22 (permalink) Old 09-23-2015, 05:30 PM
Quoted: 502 Post(s)
Passenger side for LHD. As you can see in my signature, I sell many used, but good, components. A brand new one would cost about $1100. I am much more reasonable.
post #9 of 22 (permalink) Old 09-23-2015, 05:44 PM
Date registered: Oct 2011
Vehicle: 1995 E320 Special edition, 1994 E320 Coupe
Quoted: 133 Post(s)
Mercedes engine wiring harness 1244402933 124 440 2933 29 33 updated e320 cable | eBay
Parts number:
for 1994 E320 124 440 5632
for 1995 E320 124 440 2993
pbuchmueller66 is offline
post #10 of 22 (permalink) Old 09-23-2015, 05:48 PM
Quoted: 502 Post(s)
Originally Posted by pbuchmueller66 View Post
Parts number:
2933
    1994 E320 Alternator vs Wiring Harness (Crazy Electrical Issues) MingusMingus W124 E,CE,D,TD Class 10 08-25-2010 07:35 PM
    Wiring Harness 1994 S320 kimoclutter W140 S-Class 9 03-10-2010 07:06 PM
    Wiring Harness Symptoms? '93 400E 93SoCal400E W124 E,CE,D,TD Class 13 12-15-2009 05:55 PM
    1994 mercedes e320 wiring harness JChora7 W124 E,CE,D,TD Class 1 05-03-2005 07:48 AM
    1994 mercedes e320 wiring harness JChora7 W124 E,CE,D,TD Class 3 05-01-2005 08:35 PM
