How to remove air cleaner box - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 03-13-2011, 06:10 PM Thread Starter
Date registered: Oct 2008
Vehicle: '89 420SEL, '93 300E and '07 Hyu Santa Fe
Quoted: 11 Post(s)
Hello all,
I need to change spark plugs on my 93 300e and first hurdle is how to remove air cleaner box to access plug cover?
Searched here as well as on google but could not find any good article to follow.
I have following air Cleaner box.
'93 300E 2.8, Green (205K...)
'07 Santa Fe SE, Natural khaki (95K..)
'04 S500 (122k..)
'89 420SEL, Diamond Blue (154K..) Retired
'08 kawi 250R, Red (10K..) (Sold)
MBCarGuy007 is offline
post #2 of 4 (permalink) Old 03-16-2011, 10:12 AM
GDC
Date registered: Mar 2006
Vehicle: 1994 E320, 1993 300E
You don't need to remove the aircleaner box, you need to remove the crossover tube. Simply unclip the mass air flow sensor from the filter box and loosen the top clamp on the rubber boot that goes to the ETA. disconnect any wires and move the tube out of the way. Are you sure you want to do this yourself?
GDC is offline
post #3 of 4 (permalink) Old 03-16-2011, 10:51 AM
Date registered: Jun 2009
Vehicle: W124 m104 280E 1993
devcrk is offline
post #4 of 4 (permalink) Old 03-16-2011, 12:45 PM Thread Starter
Quoted: 11 Post(s)
There is always a beginning and I did not wanted to take chance removing something that i was not sure about as plastics are brittle there and don't want to break something which should not be removed in first place.
I am more confident working on my 420sel then 300e as i worked only on that so far. Last year was for 420sel and this year will be for 300e.
Thanks for the pointers devcrk. I was unsure about removing tube over mas.
rest is done.
'04 S500 (122k..)
    Air Cleaner Box Removal / Replacement cnote2254 W126 S,SE,SEC,SEL,SD,SDL Class 3 11-13-2009 10:12 AM
    2.3 Air Cleaner Box Question maynjay W201 190-Class 1 01-11-2008 08:18 AM
    dieselized 404 air cleaner -Jeep TJ box coachgeo Unimog 3 10-22-2006 08:25 PM
    Air Cleaner/box 560 to 380 BNZ W126 S,SE,SEC,SEL,SD,SDL Class 4 01-13-2006 10:12 PM
    How do I remove the air cleaner from my 190E 2.6? Guest (MBNZ) W201 190-Class 4 07-27-2002 05:32 AM
