What type of brake fluid? - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 03-06-2011, 06:10 PM Thread Starter
Date registered: Feb 2011
Vehicle: 1991 300E 3.0
Any Problem with using Motul RBF 600 DOT4 ?
I've been using Motul for a decade or so. Just want to be sure there isn't anything unique about MB hydraulics.
Thanks.
nedro is offline
post #2 of 4 (permalink) Old 03-06-2011, 07:30 PM
ps2cho's Avatar
Date registered: Oct 2006
Vehicle: 2008 E350 4M, 1988 300TE, 2005 ML350
Quoted: 234 Post(s)
Should be fine if you've had good experience. The OE recommended product is ATE Super Blue.
Got mine ready to go in the next few weeks...
FS: Rebuilt CIS Distributor only 5k miles on it
FS: W124 1993-1995 OVP Relay (Genuine MB Brand New) PM Me if interested in either items
W124-Zone.com
2008 Black Mercedes E350 4Matic Sport P1 - 119k
1988 Pearl Grey Metallic Mercedes 300TE - 179k
2014 Jeep Wranger Unlimited Sahara - 27k
2005 Mercedes ML350 - 121k
ps2cho is offline
post #3 of 4 (permalink) Old 03-07-2011, 08:45 AM Thread Starter
I wonder if Super Blue looks green?
If so, that's what I pulled out of it last night.
nedro is offline
post #4 of 4 (permalink) Old 03-07-2011, 08:56 AM
sbaert's Avatar
Date registered: Jun 2007
Vehicle: '95 E300 DIESEL, '91 600SEL, '92 600SEL
Quoted: 935 Post(s)
Definitely agree on using ATE. Accept no substitute.
The SuperBlue is indeed blue. I use it along with ATE Typ200 fluid which is the same thing but without the blue dye. Makes for easy yearly changes as all you have to do is watch the color change at each caliper bleeder until it runs out in the same color as what you're flushing with.
The green color is simply the blue dye of the new fluid mixing with the old yellow stuff, hence green. Keep flushing until it comes out blue. At the next yearly brake flush service interval, same procedure just make sure the yellow stuff comes out.
IMO Motul is great stuff, but is more geared for bikes. And it's too expensive for use in these cars. You're better off spending the money on a set of StopTech braided flexible brake lines.
sbaert is offline
    Type of brake fluid to use for w203 cc238 W203 C-Class 1 08-09-2010 07:38 PM
    Brake Fluid type for W164 ouroboros W164 M-Class 2 10-18-2009 07:48 PM
    What type of Brake Fluid?.... doc_rage Vintage Mercedes-Benz 4 11-15-2005 05:11 PM
    What type of Brake Fluid do you use? Brewtown Benz General Mercedes-Benz 3 06-24-2005 05:18 AM
    brake fluid type jims450 R/C107 SL/SLC Class 2 03-15-2004 03:35 AM
