Tachometer not working - Mercedes-Benz Forum
post #1 of 10 (permalink) Old 02-20-2011, 09:39 AM Thread Starter
Date registered: Nov 2010
Vehicle: 1987 Mercedes 300D Turbo
For some reason the tach was working intermittently right after an oil change than stopped all together. It is possible a wire or sensor was disturbed and where should i be looking... any ideas. Im not sure where to begin on this one. would it be electronic or vacuum realated?
kzs983 is offline
post #2 of 10 (permalink) Old 02-20-2011, 04:13 PM Thread Starter
woops.... forgot to mention the make etc...
1987 300d turbo
kzs983 is offline
post #3 of 10 (permalink) Old 02-20-2011, 04:37 PM Thread Starter
The engine was running fine when the tach was working, but when it intermittantly stopped the engine would run slightly rough, now its stuck in this mode with no tach. Its the SAME thing that happens when you turn the key back slowly while turining the eninge off. Im convinced that something disturbed when the oil was changed and or the engine bay wash pressure washed.
kzs983 is offline
post #4 of 10 (permalink) Old 02-21-2011, 01:00 AM Thread Starter
I have checked numerous things and all vaccum lines are intact and working. This problem is common and it traced to the OVP relay when these symptoms exist along with ABS light and no AC. My ABS light is off and the ABS is working fine. My AC normally works however due to the extreme cold here i cant tell if it is working because the temp is below minimun AC clutch engage temp. Im thinking its the tach or rpm sensor. Anyone know where this is?
kzs983 is offline
post #5 of 10 (permalink) Old 02-21-2011, 02:25 AM
balge's Avatar
Date registered: Jun 2010
Vehicle: 93 300TD, 88 230TE
hi
603 engine, right? tach is picked up from a crank speed sensor, just below the starter (I was lying on my back and may remember the orientation wrong..)
easy to get at from below, there was one line which looked like it might be in the way but turned out not to be a problem - 5mm Allen iirc
My 300TD also had the wire trapped and crushed between the bits of firewall and stuff due to ham fisted work by PO
Ah, this might help
http://www.benzworld.org/forums/w124...00td-tach.html
cheers!
Cheers!
balge is offline
post #6 of 10 (permalink) Old 02-21-2011, 01:59 PM Thread Starter
This morning I started the car up and it took several attemps for it to fire up. Once it did the idle was still low and no tach. I drove the car to my friends shop and went right to work on the Ring Wheel Sensor, removing it i noticed that it was covered in metal particles and grease. I cleaned it with electronics part cleaner and reinstalled it, next I check all the grounds and cleaned the contacts. Started the car up and PRESTO. Idle is restored to normal and I have a working tach. Thanks for the help!
kzs983 is offline
post #7 of 10 (permalink) Old 02-21-2011, 02:43 PM
balge's Avatar
Thumbs up
Result!
Nice one, the sensor only cost me about £20 odd, but free is a good price for any repair!
Only possible fly in the ointment is how all that grunge got there in the first place? although I guess 25 years wear and tear could be a good excuse...
Cheers!
balge is offline
post #8 of 10 (permalink) Old 10-14-2013, 04:36 AM
Date registered: Feb 2009
Where is this Ring Wheel Sensor located. I have a dead tachometer as well on my 260E. Thanks.
gruber260e is offline
post #9 of 10 (permalink) Old 10-14-2013, 10:44 AM
winmutt's Avatar
Date registered: Sep 2005
Vehicle: money pits of various forms
Quoted: 95 Post(s)
Send a message via AIM to winmutt Send a message via MSN to winmutt
I have a spare one that I never installed. Will ship for $40.
winmutt is offline
post #10 of 10 (permalink) Old 10-14-2013, 10:49 AM
sbaert's Avatar
Date registered: Jun 2007
Vehicle: '95 E300 DIESEL, '91 600SEL, '92 600SEL
Quoted: 1012 Post(s)
A dead tach on a diesel can also be caused by a bad OVP relay.
Replace the OVP first with a new genuine MB or KAE(hler) relay.
sbaert is offline
1983 300SD tachometer not working retho78 W126 S,SE,SEC,SEL,SD,SDL Class 22 07-18-2012 01:09 AM
tachometer not working 85 300SD yuke W126 S,SE,SEC,SEL,SD,SDL Class 6 10-11-2008 01:28 PM
tachometer not working napoleon300DT W123 E,CE,D,CD,TD,TE Class 6 07-14-2008 03:47 AM
Tachometer Not working. davesml320 W163 M-Class 2 02-12-2006 11:12 AM
Speedometer & Tachometer not working cesarfl W126 S,SE,SEC,SEL,SD,SDL Class 1 02-11-2004 01:44 PM
