'87 300D Head Gasket questions. - Mercedes-Benz Forum
post #1 of 9 (permalink) Old 09-23-2010, 08:22 AM Thread Starter
Date registered: Sep 2010
I have an coolant leak so I took it to a dealership which told me I have an head Gasket that leaks and wants to charge $2,200 to replace. I am somewhat mechanically inclined and am thinking about doing it myself. Is this a job that should be done by someone that knows the ins and outs of Mercedes? If I do it myself, is there anything I should be aware of?
Does the head itself normally warp? Does the block usually crack?
Where can I purchase "Special Tools"?
My wife did drive it couple of weeks ago with low coolant and said it got hot! I'm not sure how hot it got but am sure that is why the head gasket now leaks.
Thanks in advance.
87tdbyer is offline
post #2 of 9 (permalink) Old 09-23-2010, 08:33 AM
winmutt's Avatar
Date registered: Sep 2005
Vehicle: money pits of various forms
Quoted: 95 Post(s)
Send a message via AIM to winmutt Send a message via MSN to winmutt
Thanks in advance.
Sounds like a new head is needed, in which case $2200 is a steal. What did the dealership say would all be done.
winmutt is offline
post #3 of 9 (permalink) Old 09-23-2010, 08:35 AM Thread Starter
The $2200 was just to replace the Head Gasket.
87tdbyer is offline
post #4 of 9 (permalink) Old 09-23-2010, 08:40 AM
Cruise Control
Zeitgeist's Avatar
Date registered: Sep 2004
Vehicle: '87 300TD/'90 300D/'94 Quattro/'89 Vanagon TDI/'01 EV Weekender VR6
Quoted: 1469 Post(s)
That price is ridiculous if they're only swapping a silly gasket. Ask for an itemized list of parts and services to be supplied with this procedure.
Zeitgeist is offline
post #5 of 9 (permalink) Old 09-23-2010, 08:45 AM
winmutt's Avatar
Quoted: 95 Post(s)
Especially when a gasket there is a good chance a gasket wont fix it.
winmutt is offline
post #6 of 9 (permalink) Old 09-23-2010, 08:48 AM Thread Starter
Is this something a backyard mechanic should do?
I looked at the Maintenance Manual didn't look to bad except for some special tools needed.
87tdbyer is offline
post #7 of 9 (permalink) Old 09-23-2010, 08:58 AM
Cruise Control
Zeitgeist's Avatar
There should only be two special tools needed for this procedure; the 12 point star socket for the head bolts, and something to pull the chain rail pins (x 2). But first you need to ascertain the source of the coolant leak. It could very well be a cracked head, and if that's the case, you're in for a new head, as I've never once seen a documented example of an original #14 head being successfully welded up and "fixed". A straight headgasket swap is more time consuming than complicated.
post #8 of 9 (permalink) Old 09-23-2010, 07:41 PM
~BANNED~
Date registered: May 2009
Vehicle: 2003 Mercedes S430
Quoted: 66 Post(s)
I've replaced head gaskets on those that leaked down the RH side of the block. I've never encountered a cracked head and the valve job, true up the head, followed by head gasket fixed it.
$2200 is about right considering the book is probably 12 hours @ $120/hr plus gaskets, shop supplies, etc.
You can do this yourself. Not too bad.
tony1963 is offline
post #9 of 9 (permalink) Old 09-26-2010, 10:05 PM
Date registered: Jul 2008
Vehicle: 83 300SD ,87 300 D Turbo, 95 E 300 D, 96 E300 D, 98 E300TD, 00 C230 Compressor, 02 C 320 Wagon,
Quoted: 8 Post(s)
seems that your car need a new head, 87's 300 D have a weak head, if was overheated 90% chance of having a crack. Don't bother having it fixed, you'll waist time, money. Better have a rebuilt one, they'll run about 1,500 ready to put on, plus gaskets.
I've been in that situation before.
mymini1 is offline
    Head gasket job questions Silversleeves W124 E,CE,D,TD Class 3 06-15-2010 08:51 PM
    91 300D 2.5 turbo blown head gasket raffo W124 E,CE,D,TD Class 4 09-21-2009 01:20 AM
    V8 Head Gasket Questions en_vogue W126 S,SE,SEC,SEL,SD,SDL Class 17 01-27-2009 01:38 AM
    S320 Head Gasket Questions... adam94 W140 S-Class 4 10-27-2008 12:27 PM
    Head Gasket Questions WhiteSEC560 W126 S,SE,SEC,SEL,SD,SDL Class 11 06-09-2007 09:21 AM
