1991 300E Rough Idle and CE light on - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 08-18-2010, 03:01 PM Thread Starter
Date registered: Aug 2010
I have a 1991 Mercedes 300E with over 200K miles. Last month I had an overheating problem so I replaced the thermostat and radiator cap. That seemed to fix the overheating issue, however at one point the vehicle overheated and the engine died. Since then the vehicle idles rough as though it is only firing on 5 cylinders. Yesterday I decided to check the compression to make sure a head gasket wasn't blown between cylinders since there is no water in the oil. All the cylinders were around 120 - 130 psi but when I took out the #3 spark plug, it was fouled. I replaced all of the spark plugs with NGK's (had Autolite in there) and replaced the sparkplug wires as well. The cap and rotor were both replaced about 10k miles ago and still look good. Replacing those items didn't fix anything. If I have the vehicle in park and start it up, it idles rough but if I rev the engine up to about 2500 - 3000 RPM's, it sounds like it smoothes out but not really sure. What is the possibility of a crank shaft sensor or whatever it is that advances the timing on this vehicle. Oh ya, the check engine light is on and it looks like the only code is a 10 which tells me that the Throttle Valve Swith (Idle Contact) is faulty. Would this cause my problem?
Last edited by jethroebodeen; 08-18-2010 at 03:21 PM. Reason: Found the trouble code.
jethroebodeen is offline
1991 500sl Running Rough on Idle scorpiox R129 SL-Class 10 09-07-2016 06:41 AM
1991 500E Rough Idle hunter500 General Mercedes-Benz 4 08-15-2010 12:43 PM
Rough idle at stop light / What is normal idle rpm? projectpete19 C208/A208 CLK-Class 3 03-11-2008 12:56 PM
Rough idle at stop light / what is normal idle rpm? projectpete19 C209/A209 CLK-Class 0 03-06-2008 10:59 AM
86 300E Rough Idle Guest (MBNZ) W124 E,CE,D,TD Class 11 05-09-2002 11:19 AM
