1988 260e fuel pump and filter location? - Mercedes-Benz Forum
post #1 of 9 (permalink) Old 07-23-2010, 04:53 PM Thread Starter
Date registered: Jul 2010
hello just bought a 260e and am new to mercedes. the filter and pump are located under the panels under the car right? any good info or pics out there to help me locate them and take off the panels. i don't know what panels to take off or how to to take off the panels. any links to steps or pics would help. thanks.
BonesMachine is offline
post #2 of 9 (permalink) Old 07-23-2010, 07:06 PM
macdrone's Avatar
Date registered: Nov 2006
Vehicle: 1993 400E 23100 miles "Gunter", 1999 ML320 200000 miles "Fizgig"
Under the rear passenger, passenger side under a bolted down cover. Right below the gas tank that is in the trunk.
macdrone is offline
post #3 of 9 (permalink) Old 07-23-2010, 07:56 PM
oefvetw124lover's Avatar
Date registered: Dec 2008
Vehicle: toys: 92 400e,92 300CE & 93 400SEL with daily driver:12 Civic, Workhorse: 15 F150
Quoted: 1144 Post(s)
Send a message via AIM to oefvetw124lover Send a message via Yahoo to oefvetw124lover
thats exactly right
Carl
Veteran
Albany, NY, USA
92 300ce and others
"Men sleep peacefully in their beds at night
because rough men stand ready
to do violence on their behalf."
Si vis pacem, para bellum
oefvetw124lover is offline
post #4 of 9 (permalink) Old 07-23-2010, 08:42 PM
Jayare's Avatar
Date registered: Jun 2005
Vehicle: 86 190E 2.3L 16V, 93 400E, 95 320TE, 95 E320, 98 S500
Quoted: 613 Post(s)
The cover protecting the fuel pumps and filter is made of heavy plastic. It is held in place by 4 plastic 10mm nuts. Jack up and secure the right rear of the car. It is the only thing you'll see under the right rear passenger seat. When you change the filter, do so in a very well ventilated area as their will be gas that leaks/runs when you disconnect the filter. It is a simple affair and you shouldn't have any problem completing this, just be quick.
Good Luck,
Jayare
Jayare is offline
post #5 of 9 (permalink) Old 07-23-2010, 11:31 PM Thread Starter
thanks. found the filter and what looks like 2 fuel pumps? the car wasn't starting before. i hot wired both pumps to the battery and the car started. are both these pumps supposed to be on all the time when the car is running? thanks again.
post #6 of 9 (permalink) Old 07-24-2010, 12:36 AM Thread Starter
it's kinda funny. i don't even have any $$$ for a new relay or whatever is causing the fuel pumps to not get power....i was thinking as a temp fix i could "somehow" wire the key in while door is open buzzer from the ignition as the on and off for the fuel pumps. just wondering if both the fuel pumps are supposed to be on all the time when the car i running. thanks
post #7 of 9 (permalink) Old 07-24-2010, 04:23 AM
Jayare's Avatar
Quoted: 613 Post(s)
Bones,
The fuel pumps should run while the car is running. When first energized, the pumps will "prime" the system then shut down. When the engine starts, they will then run constantly. Your car has a fuel pump relay that I believe is located behind the plastic shield, behind your battery. If not, others on the forum will correct me and provide the correct location.
There is a two prong connection for the pumps located under the passenger rear seat bottom. You might use that for your connection point until funds are available for the relay. Relay's are a tic over $100 or you could possibly find one in working order at a pull-it yard. The relay looks like this....
Good Luck,
Jayare
Jayare is offline
post #8 of 9 (permalink) Old 07-24-2010, 05:26 AM
augapfel's Avatar
Date registered: Jan 2006
Vehicle: About a dozen 1988, 1989, 1990, and 1991 sedans, wagons, and 4Matics; drivers, projects, and parts
Quoted: 20 Post(s)
The pumps work as a pair, both running at the same time, to ensure adequate fuel flow at all times. Much of the fuel sent to the engine isn't used and goes back to the fuel tank.
How many people here know that the fuel return line includes a heat exchanger located under the intake manifold? The fuel returnng to the tank is cooled by the air conditioner suction line whenever the a/c is operating.
augapfel is offline
post #9 of 9 (permalink) Old 07-26-2010, 04:14 AM Thread Starter
hey thanks. i ended up hot wiring the pumps to fuse #7 before the actual fuse. this fuse turns on in key position 2 and when the car is running.
    1988 260e w124 no fuel...changed fuel pump and relay!! salthepal W124 E,CE,D,TD Class 11 01-07-2012 09:32 AM
    88 260E/300E fuel pump life augapfel W124 E,CE,D,TD Class 1 11-08-2006 02:24 PM
    260E Fuel Filter - Easy to Change? addygirl W124 E,CE,D,TD Class 4 05-16-2006 03:14 PM
    fuel filter location Fsuperb W163 M-Class 9 09-22-2005 10:18 PM
    Where is the fuel filter on 1988 300 Coupe? gogoni W124 E,CE,D,TD Class 1 03-07-2004 03:07 PM
