1987 300 TD Timing - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 07-05-2010, 12:35 PM Thread Starter
Date registered: Jul 2008
Vehicle: 83 300SD ,87 300 D Turbo, 95 E 300 D, 96 E300 D, 98 E300TD, 00 C230 Compressor, 02 C 320 Wagon,
Quoted: 8 Post(s)
1987 300 TD Timing
The vacuum pump broke damaging the pulley that activates it, therefore I have to replace the pulley but Don't know how to put the timing on a diesel, I have knowledge on gasoline cars but not diesel, could anyone suggest a web site, link or e-mail me something where I could read and understand about it? better yet if have done this job before and could exchange some information will be very helpful.
I'm inserting pictures of the vacuum pump( I already have a replacement) and a picture of the damaged gear.
Thanks,
Mymini1
ID:	317651   Click image for larger version
ID:	317652   Click image for larger version
mymini1 is offline
post #2 of 3 (permalink) Old 07-05-2010, 01:21 PM
Cruise Control
Zeitgeist's Avatar
Date registered: Sep 2004
Vehicle: '87 300TD/'90 300D/'94 Quattro/'89 Vanagon TDI/'01 EV Weekender VR6
Quoted: 1541 Post(s)
Bummer. These issues seem to be cropping up more and more now that the cars are aging. You'll need to swap out the injection timer, which either took out the vacuum pump, or the other way around. The function of the ramp is critical for the long term health of the pump. This link should provide you with all the guidance you'll need to swap both out and then set the timing. Incidentally, it's preferable to have the proper timing tools, but it can actually be done with little more than a flashlight and a mirror, if needed.
Zeitgeist is offline
post #3 of 3 (permalink) Old 07-05-2010, 08:29 PM Thread Starter
Quoted: 8 Post(s)
Thank you for the link very good information.
mymini1 is offline
    1987 560SEL Timing procedures dwaldy W126 S,SE,SEC,SEL,SD,SDL Class 3 10-30-2008 10:30 PM
    FS 1987 300 TD stigmata For Sale/Wanted/Trade/Giveaway 4 06-23-2008 12:34 PM
    1987 Mb 300 Td June Kleider Test 0 03-14-2007 05:36 PM
    Changed the timing chain in my 1987 230E but....... lemmyb W124 E,CE,D,TD Class 0 09-28-2004 02:18 PM
    1987 E 300 Speakers. Help! Plopp General Mercedes-Benz 1 06-14-2004 03:34 PM
