Front seat Motor Problem - Mercedes-Benz Forum
post #1 of 11 (permalink) Old 06-27-2010, 02:32 PM Thread Starter
Date registered: Jan 2010
Vehicle: 1988 300TE 280,000 Miles
I have a torn seat back so I'm removing the Driver's front seat.
One of my rear "raise" motors is not working. Are there anythings to look for, or just replace it? It looks like a belcrank/gear design. One side raises and the other side doesn't.
Les_Garten is offline
post #2 of 11 (permalink) Old 06-27-2010, 03:54 PM
augapfel's Avatar
Date registered: Jan 2006
Vehicle: About a dozen 1988, 1989, 1990, and 1991 sedans, wagons, and 4Matics; drivers, projects, and parts
Quoted: 20 Post(s)
Are you absolutely sure its the motor? Motor failure is rare -- seat switch failure is not.
augapfel is offline
post #3 of 11 (permalink) Old 06-27-2010, 03:58 PM Thread Starter
Yeah, gotcha.
The thing is that when I actuate the switch, one side raises and the other side does not.
post #4 of 11 (permalink) Old 06-27-2010, 04:14 PM
augapfel's Avatar
Quoted: 20 Post(s)
Doesn't matter. The front contacts can be good and the back contacts bad. Not uncommon.
You need to unplug the switch and jumper the harness terminals to see if the motor works. Need wire colors?
augapfel is offline
post #5 of 11 (permalink) Old 06-27-2010, 06:20 PM Thread Starter
Hi,
Yeah, colors would be awesome.
So the left rear works for me but the right rear doesn't. Kinda made getting the seat out a B*ITCH!
post #6 of 11 (permalink) Old 06-29-2010, 12:01 PM
clos650's Avatar
Date registered: May 2009
Vehicle: 1990 300E 2.6 174,000Miles
Send a message via AIM to clos650
Yeah same thing with my passenger seat back motor didn't work turned out it was the switch was not hard to fix
clos650 is offline
post #7 of 11 (permalink) Old 06-29-2010, 12:04 PM Thread Starter
Good News then! Only one side was working for you as well?
post #8 of 11 (permalink) Old 06-29-2010, 01:01 PM
clos650's Avatar
yea was an easy fix just opened the switch up and cleaned all the metal contact
clos650 is offline
post #9 of 11 (permalink) Old 06-29-2010, 03:22 PM Thread Starter
Thanx, I have some Cramolyn R5 that should suite this perfectly.
post #10 of 11 (permalink) Old 06-29-2010, 07:42 PM
Date registered: Dec 2009
Vehicle: 1999 ML320
Quoted: 7 Post(s)
Not sure if the switch will do it, but give it a try.
I had the same problem with mine the other day. One side of the drivers side would go up and the other would bind.
Both sides are driven by the same motor (why I don't think the switch will fix it). The motor has a drive cable coming out either side. One cable goes to one side and the other opposite. What fixed it for me was to move the seat all the way forward so I could get good access to the gear drive mechanism (on the broken side obviously). Gently yank the black plastic covers off that cover the tilt mechanism. Remove the four screws that hold the cover on and you will see a worm gear that drives a large plastic gear for the tilt. Take a slot screwdriver and gently pry out the worm gear. You will find a rough square cable protruding from the cable drive. This is supposed to slip into the worm gear to drive it.
In my case the cable had worked its way too far out at the other end and no longer "plugged" into the motor. Thus no drive. After a couple of attempts to reposition it and reassemble, it would simply keep working its way out.
In the end I positioned the cable half way into the motor and half way into the worm gear. Only this time I added JB Weld to the end of the cable before I inserted it into the worm gear. I carefully reassembled so as not to move the cable out of position and resisted the urge to try it out till the next day. All was well and it has worked ever since.
Note: There is a DIY on this but that person had a stripped worm gear. Ultimately a similar solution.
Good luck.
-Derek
biffidum is offline
w208 clk front seat fore/aft motor how to poptopclk C208/A208 CLK-Class 98 08-06-2016 12:42 PM
Power Seat Motor or Switch Problem dmlawsonesq W210 E-Class 7 08-19-2015 12:04 PM
Looking for front licence plate holder & seat motor Thomasbhughes C208/A208 CLK-Class 1 02-24-2009 10:40 PM
front seat seat back motor location mjtrac W126 S,SE,SEC,SEL,SD,SDL Class 0 05-12-2007 09:29 AM
Help! Front seat electric motor died... ccweems W163 M-Class 8 11-25-2002 10:57 AM
