1992 300E 4Matic fuel filter and fuel pumps problem - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 05-03-2010, 02:24 AM Thread Starter
Date registered: Mar 2010
Vehicle: 1992 300E 4MATIC
Post 1992 300E 4Matic fuel filter and fuel pumps problem
I have 1992 300E 4Matic (168,000 miles), it was sitting my father garage for the last 3 years. It startup fine, when I press on the accelerator; there is a lot of hesitation and it’s slow to accelerate. Sometimes it stalls out. So I was thinking maybe since it was sitting in the garage for three years the fuel system is probably picking up a lot of dirty fuel maybe I should replace the fuel filter.
So I started on this journey to replace the fuel filter. I had trouble taking the old filter off. It was very difficult; I think the fuel filter is the original from 1991 or 1992. I was only able to slightly move the fuel line on the “out” end of the fuel filter; I was never able to unscrew the “in” end of the fuel filter. I tried a lot twisting and turning trying to get this sucker off. I gave up on my pursuit to replace the fuel filter. I put the braces back on the fuel pumps, fuel filter and fuel accumulator. I hooked it back up under the car with the rubber hangers.
I see no visible fuel leaks. As a precaution, before I put the protective cover back on I turn the car on to check for leaks.
When I turn the car on and I look under the car at the fuel pumps and fuel filter, I see fuel spilling out (almost gushing out) so I turn the car off and the leaking (or gushing) stops. I don't even see any small leaks.
Do you have any advice on how to fix this problem and possibly how to take this stubborn fuel filter off? Or should I give up and take this problem to my local Mercedes-Benz mechanic. Trying to save money, I don’ t have a lot of money. I inherited this car from my father; this is the only thing he left me when he died so I’m trying to keep it.
Any good advice would be greatly appreciated...
smt3 is offline
post #2 of 3 (permalink) Old 05-03-2010, 08:44 AM
augapfel's Avatar
Date registered: Jan 2006
Vehicle: About a dozen 1988, 1989, 1990, and 1991 sedans, wagons, and 4Matics; drivers, projects, and parts
Quoted: 20 Post(s)
Does the pump setup look like this:
augapfel is offline
post #3 of 3 (permalink) Old 05-03-2010, 02:01 PM Thread Starter
Red face It looks something like this picture Except...
It looks something like this picture except My car has two fuel pumps. Do you have any advice for my problem?
Thanks...
smt3 is offline
    1997 S500 No Fuel at Injectors (fuel pumps already replaced) dleroux W140 S-Class 11 03-24-2012 03:46 AM
    300e hesitation maybe fuel pumpS Naj W124 E,CE,D,TD Class 10 11-19-2009 09:04 AM
    '97 C280 Fuel Tank (leak) and Fuel Pumps marvinstockman W202 C-Class 0 11-26-2008 06:16 AM
    fuel air mix / testing fuel pumps and pump pressure william.wood W126 S,SE,SEC,SEL,SD,SDL Class 0 11-09-2005 11:32 AM
    How many fuel filters & pumps for 91 300E? alee4 W124 E,CE,D,TD Class 0 10-07-2002 06:40 AM
