1994 E320 - can't pull dianostic codes - Mercedes-Benz Forum
post #1 of 9 (permalink) Old 03-29-2010, 02:00 PM Thread Starter
Date registered: Jan 2009
Vehicle: 1994 E320 with 223,000 miles and going strong!
Send a message via AIM to NitroTrike Send a message via Yahoo to NitroTrike
My 1994 E320 has had the 'check engine' light on for some time. Than it sat as I procrastinated fixing the leaking galley plug. After that was all done, I drove it few times - and BAM there's the light again.
It never seemed to effect gas mileage, or drivability.
I've read I am supposed to pull the cover off of a box in front of the battery - ok, found it.
Now, I am supposed to have the key on, but engine off - ok, done.
I am now supposed to hold the little button for 3-4 seconds, and this mystery light next to the button should start blinking in sequence. Won't happen.
I even tried the 6-8 seconds to reset the light. Won't work either.
Is there a way to see if this mystery port / switch / light is even plugged into anything??
Am I doing this procedure wrong?
NitroTrike is offline
post #2 of 9 (permalink) Old 03-29-2010, 02:56 PM
Date registered: Jul 2004
Quoted: 337 Post(s)
With car "on" are the dash warning lights lit up? When you push the button down does the LED light up, then go off when you release?
deanyel is online now
post #3 of 9 (permalink) Old 03-29-2010, 07:45 PM
Premium Member
acarter53's Avatar
Date registered: Dec 2006
Vehicle: 2012 C300 Sport 4Matic and 2003 CLK430 Cabrio
Quoted: 24 Post(s)
Premium Member
+1 The car needs to be (on) to read the codes. Been there done that too
acarter53 is offline
post #4 of 9 (permalink) Old 03-30-2010, 05:53 AM Thread Starter
Yes, I made sure the dash lights (and the annoying buzzer momentarily) was on. The LED does not light in any way, nor does holding the button for 6-8 seconds (as per instructed on another site) reset the dash warning light after cycling the key. This is making me think this whole thing may be disconnected from somewhere.
Would I be able to use a voltmeter to see if any of the other ports / holes are getting voltage, to verify this thing is even plugged in to something?
post #5 of 9 (permalink) Old 03-30-2010, 06:14 AM
Premium Member
acarter53's Avatar
Quoted: 24 Post(s)
Premium Member
Is the engine running?
post #6 of 9 (permalink) Old 03-30-2010, 06:41 AM
Quoted: 337 Post(s)
Pin 1 is ground and pin16 is 12v, not on all 16 pin connectors, but should be on a 1994. If you can't get a circuit there it's dead, which could be a fuse.
post #7 of 9 (permalink) Old 03-30-2010, 07:53 AM Thread Starter
I was told to do it with the engine not running, but the ignition in the "on" position.
post #8 of 9 (permalink) Old 03-30-2010, 09:00 AM
Premium Member
acarter53's Avatar
Quoted: 24 Post(s)
Premium Member
I had several lights when i first purchased my car. At first i could not get the light to come on at all. I found a post that said
1) Hold the button down for 3 sec.
2) count the blinking light.
3) hold for another 8 sec to clear code.
4) cycle trough until you see the first code again
5) Turn car off and restart and engine light should be off.
I worked every time
post #9 of 9 (permalink) Old 05-30-2012, 08:41 AM
Date registered: Dec 2010
Vehicle: 1994 E320
Similar problem on my 94 E320..... the CEL is on on the dash and when I press the button down, the red LED is on. When I let up on the button the LED goes off. No matter how short or long I hold it down, the result is the same. The LED goes off as soon as I let up on the button and never flashes. I am doing this with the key on, engine not running.
pnokes is offline
Reading the engine codes 1994 E320 hantour W124 E,CE,D,TD Class 22 04-24-2013 12:10 PM
pull codes finalstage1 W126 S,SE,SEC,SEL,SD,SDL Class 4 02-11-2010 02:21 PM
1994 E320 Diagnostic codes dshaver2000 W124 E,CE,D,TD Class 3 07-15-2008 03:50 PM
How to pull codes thru the 38 pin connector THX W140 S-Class 12 01-29-2007 02:29 PM
How to Pull and Clear Codes DIY. pcmaher W140 S-Class 1 01-04-2006 07:31 PM
