» Featured Product
» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Sedan Forums > W124 E,CE,D,TD Class
Old 03-09-2010, 03:42 PM   #1 (permalink)
Date registered: Feb 2007
Vehicle: 1994 E220 Coupe
Replacing air con vent light
How would I go ahead with replacing the little light on the center air vent?
The light in question is the one on the dial that rotates to allow or stop air from passing through the corresponding vent.
fifalex is offline   Reply With Quote
Old 03-09-2010, 04:02 PM   #2 (permalink)
Date registered: Jun 2009
Vehicle: 1991 300E
Someone took a swipe at your question here
http://www.benzworld.org/forums/w124...edes-300e.html
Looks like a PITA, you might consider living with it.
300E91 is offline   Reply With Quote
Old 03-09-2010, 09:44 PM   #3 (permalink)
Vehicle: 1991 300E
Ha, found a write-up in the online maintenance manual, here
How to Remove Dash Vents in Model W124 Models
If you're not familiar with it, you should book mark this
Model 124 Maintenance Manual Index
Old 03-10-2010, 05:58 AM   #4 (permalink)
Thank you
fan blows out hot air with air con on clemmahoney V-Class 3 03-14-2010 05:01 PM
Central vent cold air, side vent warm air, help please Benz235 W202 C-Class 6 07-24-2009 11:38 PM
Pictorial DIY - replacing driver side vent wheel light Kobus W210 E-Class 18 06-19-2008 01:06 AM
need help, ANY, on replacing air vent on 190e!!! Guest (MBNZ) W201 190 Class 2 11-04-2001 11:04 PM
The light on the rotary dial for the passenger side air vent died. How does one replace it? Guest (MBNZ) W210 E-Class 2 10-10-2001 03:12 PM
