» Featured Product
» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Sedan Forums > W124 E,CE,D,TD Class
Old 03-09-2010, 06:44 AM   #1 (permalink)
Date registered: Mar 2003
Vehicle: 450SE and 190E
88 260e question
I have a 260e that the backend sways back and forth when you step on the gas and when you hit bumps. Has anyone else experienced this? I was told stabilizer pins but just wanted to get another opinion.
BigBenz is offline   Reply With Quote
Old 03-09-2010, 07:24 AM   #2 (permalink)
tuttebenne's Avatar
Date registered: Jul 2005
Sounds like the bushings at the ends of the rear suspension links are shot. This is common. Under normal braking I never noticed a problem but under heavy braking the car actually steered to the left. The lower links on both side were the cause in my case. They are relatively cheap and easy to install. They come with new hardware from M/B.
'88 300E
'89 300E
'93 400E
'93 500E
'77 308GTB
tuttebenne is offline   Reply With Quote
Old 03-09-2010, 08:17 AM   #3 (permalink)
Date registered: Oct 2006
Vehicle: 1988 300TE, 1987 260E
^ This. Same deal on my wagon. You'll need to buy a new rear control arm set.
When I accelerate it turns to the left, but when I lift off, it returns to the right. It's most noticeable on the freeway.
ps2cho is offline   Reply With Quote
Old 03-09-2010, 02:41 PM   #4 (permalink)
augapfel's Avatar
Date registered: Jan 2006
Vehicle: 88 260E, 88 300TE x 2, 88 300E x2 (parts), 90 300TE 4Matic (parts)
^+2
The rear end control arm bushings are shot. Very common. You just replace the whole arm assembly as necessary. The lower, front arm forward bushings seem to go first in my experience.
augapfel is offline   Reply With Quote
Old 03-10-2010, 06:30 AM   #5 (permalink)
Thanks fellas im going to take the car to be repaired tomorrow.
W124 260e window regulator question xplayboy2434 W124 E,CE,D,TD Class 1 08-06-2009 06:20 AM
Is an '87 260E... LGF W124 E,CE,D,TD Class 4 12-20-2006 11:17 AM
260E question Raxhi W124 E,CE,D,TD Class 1 11-08-2006 04:53 AM
'89 260e wardhill W124 E,CE,D,TD Class 0 04-27-2004 08:25 PM
'89 260e - Cooling System Question? Guest (MBNZ) W124 E,CE,D,TD Class 2 04-03-2001 04:40 PM
