Oil Change through dipstick tube - Mercedes-Benz Forum
post #1 of 12 (permalink) Old 03-02-2010, 04:19 AM Thread Starter
davegt's Avatar
Date registered: Oct 2008
It is time to do an oil change in both the ML and the E420...
So, I thought I would change my procedure and pick up an oil transfer pump like a Mityvac or something to do the oil removal through the dipstick tube.
Any recommendations on a reasonably inexpensive but good pump?
best regards,
dave
1999 ML 320 (Black) 198k
(Proudly wearing it's 250,000km Badge!)
1995 E420 (Sapphire Black) 70k
1978 450 SEL (Grey) - Sold
Join the MBCA!
davegt is offline
post #2 of 12 (permalink) Old 03-02-2010, 04:28 AM
Aero I's Avatar
Date registered: Sep 2008
Vehicle: 04 E500; 00 SL500 Sport/Pano; 99 SL500 Pano; 94 E420; 92 500E; 92 300CE; (81 380SL-Retired)
Quoted: 125 Post(s)
MityVac
You already mentioned the one I use, found cheap on eBay, works great.
Just don't get the oil Too hot, it will deform the plastic tubes, they tell you in the instructions.
Either stop running the engine before it reaches normal temp, or wait a half/hour or so after you stop motor.
this is not the pumps fault, it's the plastic tubing, probably the same for any pump you buy.
SL's & 124's
Aero I is offline
post #3 of 12 (permalink) Old 03-03-2010, 06:27 AM
Date registered: Feb 2007
Vehicle: 1994 E220 Coupe
Is this method as effective as draining through the sump plug?
My mechanic does this with a container that has a vacuum but I always felt it doesn't remove as much oil as draining from the sump would
fifalex is offline
post #4 of 12 (permalink) Old 03-03-2010, 07:49 AM
mckellyb's Avatar
Date registered: Sep 2007
Quoted: 6 Post(s)
I've always felt the same, however, since having an MB oil pan off the car, I can say that, fully drained when pretty warm, there is still about 1/4-1/3 of a quart in the pan due to the way it is shaped. It was certainly this way on my 420 SEL's pan, and based on the color of the oil immediately after the first change on my E320, and looking at the pan itself, the same thing happens in this engine's sump.
I've since decided it'll be faster, easier, and I'll get to look at some items while doing it, to jack up the LR of the E320 so oil in the 'reserve' area can't hide from the plug drain. The drain on the 320's pan is at the right-front of the engine, so lifting the LR a decent amount will get it.
Plus, I'll not have a choice but to roll around and look at CV bellows and other stuff typically not noticed until it's past fixing the existing part(s).
Kelly B
'05 Cadillac STS, V8, pearl white, 137K miles, my DD
Wife's ride: '02 Lexus RX300 AWD, all the options but a hitch, 130K miles
'99 Fleetwood Bounder Diesel 39Z diesel pusher motorhome, which has visited 9 provinces, 1 territory, and 49 states under our ownership, 135K miles and many modifications
'98 Jeep Grand Cherokee 5.9L, dedicated 'toad' 165K miles
mckellyb is offline
post #5 of 12 (permalink) Old 03-03-2010, 12:57 PM
dusty88's Avatar
Date registered: Feb 2009
Vehicle: 1988 300E
I got a miyvac on amazon--it hold about 8L. I would highly recommend oil changes with this method. There will always be some old fluid left, no matter which method
dusty88 is offline
post #6 of 12 (permalink) Old 03-03-2010, 09:10 PM
Real1shepherd's Avatar
Date registered: Jul 2009
Vehicle: '92 300TE 4matic 270,000miles
Quoted: 250 Post(s)
If you have a compressor, DO get the model that hooks up to same. It will shorten your 'pump time' exponentially.
Lots of dealers drain oil through the dipstick. What I do is alternate. Once with the compressor and then alternate by pulling the plug on the next change. I think that's the best of both worlds. Make sure your drain plug is magnetic as well.
Kevin
Real1shepherd is offline
post #7 of 12 (permalink) Old 03-04-2010, 06:15 PM
Date registered: Feb 2010
Vehicle: 1987 300D
I use a pump out system on my '87 300D. I back the car in the driveway (nice grade) this puts the dip stick at lowest point. Hook the pump up to the battery, insert the tube down the dip stick tube, turn it on and while it's pumping I get all the other stuff ready. Heat does not affect the tube as it is only for oil changes and doesn't deform in hot oil. I use this method on all the boats I work on and even more so with four stroke outboards to limit the amount of oil that may go overboard.
bdtsr is offline
post #8 of 12 (permalink) Old 03-04-2010, 07:07 PM
Date registered: Aug 2008
Vehicle: 2008 E320 Bluetec, 1988 560SL totalled unto death). 1997 Dodge Ram 1500, 1983 300CD
Quoted: 177 Post(s)
Oil sucker
The dipstick tube does not end after it enters the engine block. It extends through the crankcase to the lowest point in the oil pan. The MityVac kit includes a plug that seals snugly into the dipstick opening. The plastic suction tube attaches at the center of that plug and need not pass all the way through the dipstick tube. The dipstick tube itself is used to withdraw the oil.
By this method, more oil will be removed than by draining. This is not to say a periodic undercar inspection is not a good thing.
rocky raccoon is offline
post #9 of 12 (permalink) Old 03-04-2010, 07:54 PM
Date registered: Jul 2004
Quoted: 312 Post(s)
You should say "honest" at the end of the sentence. Then we could all trust you implicitly. Or alternativley you could provide some support for the claim.
deanyel is offline
post #10 of 12 (permalink) Old 03-05-2010, 03:25 AM
Quoted: 177 Post(s)
The best I can do
Read mckellyb's post. The drain plug is not at the lowest point of the oil pan. This is true for the OP's car and all M117 engines. I cannot say for certain irt all MB engines.
    Location of transmission oil dipstick tube mescaline W211 E-Class 20 03-04-2009 10:40 PM
    Oil change tube location garygmk W211 E-Class 6 08-10-2008 03:41 PM
    No dipstick DIY oil change keyhole General Mercedes-Benz 8 06-01-2007 11:54 AM
    Oil coming out dipstick tube white500se W126 S,SE,SEC,SEL,SD,SDL Class 11 05-19-2005 10:40 PM
    Dealer suck oil out of dipstick tube or bottom of Roger R170 SLK-Class 4 06-17-2002 02:23 PM
