W 124 Wiper Repair - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 02-14-2010, 02:29 PM Thread Starter
Date registered: Mar 2009
Vehicle: 1994 S350D
W 124 Wiper Repair
I have a eurpoean import 1986-87 300D wiper that was starting to get slow and beginning to shutter when moving. It seems to not have the same speed between normal and fast when switched to that mode. I got a used 1991 replacement (entire assembly) and installed it just fine. But when turning it on it does not stop or obey the switch signals. I have to turn off the key. I noted that the motor number is slightly different but other than that everything seems identical. I thought the 124 series wipers were interchangable if it would install correctly and everything else. Does anyone have any experience with this? Have I installed the wiper properly?
thanks
Rhoadrw
rhoadrw is offline
post #2 of 3 (permalink) Old 02-15-2010, 03:18 AM
Jayare's Avatar
Date registered: Jun 2005
Vehicle: 86 190E 2.3L 16V, 93 400E, 95 320TE, 95 E320, 98 S500
Quoted: 591 Post(s)
Look in the DIY Thread of this forum. Under "Electrical" you'll find a link addressing your question. Please take a few minutes to complete your profile. It helps all of us, better help you. Welcome
Jayare
Jayare is offline
post #3 of 3 (permalink) Old 02-15-2010, 09:29 AM
necromancer's Avatar
Date registered: Aug 2007
Vehicle: 1990 Mercedes Benz 300E
Check to make sure the pin assignments are the same on the harness that connects the wiper motor to the stalk. Personally, I would've just taken apart the whole wiper assembly (early ones used the much beefier solid alloy lids on the mechanism necessitating the disassembly of the linkage) and lubed everything with Gleitpaste and strategically placed drops of ATF).
Did that to mine and it works like new now (going on 2 yrs).
necromancer is offline
    300SL Single Wiper Repair hifeverz R129 SL-Class 4 02-01-2015 02:14 PM
    $124 to replace wiper blades?!?!? W140FTW W140 S-Class 22 03-20-2008 07:58 AM
    Repair Log from a 17 year owner of a 124 jodyt W124 E,CE,D,TD Class 0 01-09-2007 09:07 AM
    Wiper Motor & Linkage Repair lukacst R/C107 SL/SLC Class 1 12-23-2005 02:29 PM
    124 radiator repair Guest (MBNZ) W124 E,CE,D,TD Class 0 08-25-2001 07:13 AM
