vss or speed pulse wire - Mercedes-Benz Forum
post #1 of 8 (permalink) Old 12-12-2009, 01:39 AM Thread Starter
Date registered: Jun 2006
anyone no where the vss/speed pulse wire is located, i have a 300ce and im fitting a pioneer satnav screen, i was told behind the instrument cluster, any ideas and the wire colour.
thanx bobby
D4LJE is offline
post #2 of 8 (permalink) Old 12-12-2009, 02:04 AM
augapfel's Avatar
Date registered: Jan 2006
Vehicle: About a dozen 1988, 1989, 1990, and 1991 sedans, wagons, and 4Matics; drivers, projects, and parts
Quoted: 20 Post(s)
The wire you're looking for is green with a yellow stripe and it runs from the back of the speedometer to a junction block under the dash. Pics below. When you pull the cluster be sure to 1) telescope the steering column outward as far as it will go and 2) unclip the speedo cable from the plastic shield under the dash at the steering column. There's probably an unused pin on the signal distribution block X53/5 so no need to cut or tap into the wire itself.
ID:	278751   Click image for larger version
augapfel is offline
post #3 of 8 (permalink) Old 12-12-2009, 04:13 AM Thread Starter
thanx mate. your a star!!!
D4LJE is offline
post #4 of 8 (permalink) Old 12-12-2009, 07:46 AM
Date registered: Dec 2007
Vehicle: 94 E320 Wagon--218K miles, 1995 E320 Sedan--101K miles, 1994 E500 Sedan--78K miles
Depending on your model and year, you may be able to get the speed signal from an input to the back of radio. The stereo system uses this input to adjust volume according to vehicle speed..... Much easier access than pulling the cluster.
J. M. van Swaay
J. M. van Swaay is offline
post #5 of 8 (permalink) Old 08-08-2012, 06:37 PM
Date registered: May 2008
Vehicle: MB 300D turbo 1993, MB 1989 300E converted to diesel
Send a message via Skype™ to oldbeaver
VSS signal monitoring and injector signal
Thank you very much for sharing this valuable information!
Do you know where to spot the injector signal?
OldBeaver
oldbeaver is offline
post #6 of 8 (permalink) Old 09-05-2012, 12:29 PM
Vehicle: SL500 (R129), 500 SEC (W126)
Quoted: 6 Post(s)
How many pulses per revolution are there? The old school Becker sat nav that I am installing min my car asks for this information. Thanks for any help given!
JJRodger
'99 SL 500
'93 E300 D T
'90 190
jjrodger is offline
post #7 of 8 (permalink) Old 05-29-2014, 03:35 AM
Date registered: May 2014
Vehicle: w126 280se 1984
Hi everybody
If anybody still looking this old forum, may help me to locate this wire in my w126 280se by PM or response to this m.
Thanks
kamran49 is offline
post #8 of 8 (permalink) Old 05-29-2014, 07:30 AM
NobleTruths's Avatar
Date registered: Oct 2013
Vehicle: 1995 E320 Cabriolet x 2
Location: If you live north of the Texas Red River, you are a damn yankee!
Quoted: 502 Post(s)
Originally Posted by kamran49 View Post
Hi everybody
Thanks
While someone here might know, you would more likely find better help in the W126 sub-forum:
W126 S,SE,SEC,SEL,SD,SDL Class - Mercedes-Benz Forum
I have several wiring harnesses (E300/320 and E400/420), ETA's, side/tail/headlights and trim for sale. I can also get requested parts from local JYs. PM me.
NobleTruths is offline
    speed sensor / speed pulse wire okbarnett R230 SL-Class 0 02-09-2009 11:32 AM
    need to know which is speed pulse wire bradelee W126 S,SE,SEC,SEL,SD,SDL Class 6 04-08-2007 11:52 AM
    Speed sensor/vss wire scoopcoupe W124 E,CE,D,TD Class 1 02-14-2007 08:09 AM
    Mercedes ML320 w163 speed pulse wire baff57 Audio & Telematics Forum 7 09-06-2006 07:37 PM
    Sat Nav Speed Pulse wire info...... V280 V-Class 0 04-30-2005 01:27 PM
