Cost of diesel engine (rebuilt) for '87 300TD - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 06-26-2009, 09:58 AM Thread Starter
Date registered: Jun 2009
Does anyone know what the average price would be for a REBUILT engine on a Merc diesel 300TD wagon (1987)? Would this price be any different in mid-late '07 when diesel was much cheaper than it would currently, in mid '09? How much would the price vary depending on the work put into it to rebuild it? If a significant amount of work was done to rebuild it, what would the top price be? I'm looking for the price of the engine itself; not labor to install it.
PopcornDude is offline
post #2 of 6 (permalink) Old 06-26-2009, 10:13 AM
fairon's Avatar
Date registered: Nov 2008
Vehicle: 2000 E320 4Matic Wgn
IIRC, the 300TD in '87 (W124 chassis) has the OM603 in either turbo or N/A variants. I'm pretty sure the US only got turbo engines and the OM603 is known to have some problems with the head. I can't tell you how much it would be to rebuild, but you may want to try your question in the W124 forum. They'd be much more likely to know.
fairon: 00 E320
fairon is offline
post #3 of 6 (permalink) Old 06-26-2009, 11:15 AM
diametricalbenz's Avatar
Date registered: Oct 2005
Vehicle: '77 6.9, 74 240D, 96 Ram 5.9L Cummins, 02 Civic EX, 10 Mazda 5 Sport
Quoted: 4 Post(s)
The US had only turbo versions. A full rebuilt motor will run $9000.
Mercedes Rebuilt Engines
Fuel prices have absolutely nothing to do with labor and engine parts.
1977 - W116 - 6.9
1974 - W115 - 240D /8 - 4(M) OM617.910 + Turbo + 300D FW - Completed 7/8/10
diametricalbenz is offline
post #4 of 6 (permalink) Old 06-26-2009, 12:13 PM
Cruise Control
Zeitgeist's Avatar
Date registered: Sep 2004
Vehicle: '87 300TD/'90 300D/'94 Quattro/'89 Vanagon TDI/'01 EV Weekender VR6
Quoted: 1647 Post(s)
MB has recently jacked prices for most of the parts needed, so it would be more expensive now than in '07. I may find out soon enough, 'cause I'm thinking about rebuilding and selling the bottom end that I just pulled from my '87. Sleeves, pistons/rings, and main/rod bearings = Big dollah
Zeitgeist is offline
post #5 of 6 (permalink) Old 06-26-2009, 12:47 PM
augapfel's Avatar
Date registered: Jan 2006
Vehicle: About a dozen 1988, 1989, 1990, and 1991 sedans, wagons, and 4Matics; drivers, projects, and parts
Quoted: 20 Post(s)
Last year when I was trying to reel in an 87 diesel sedan with supposedly a bad motor I researched OM 603 rebuilt prices. $9000 was the magic number then. It's an absurd amount of money to put into a 22 YO passenger car unless you intend to drive the thing for another 250k+ miles. Otherwise you're flushing money down the toilet.
The 87 engine does have cylinder head cracking problems and used heads are virtually nonexistant. Revised heads from such aptly-named MBZ diesels as "the rod bender" bolt on and don't have the cracking problem.
augapfel is offline
post #6 of 6 (permalink) Old 06-26-2009, 02:33 PM
necromancer's Avatar
Date registered: Aug 2007
Vehicle: 1990 Mercedes Benz 300E
Yeah, that's the thing with OM series engines. They are rare enough on this side of the pond that you can't just circumvent a rebuild and drop in a low-mileage example as easily as you can with a gasser.
I'm sure that's factored into the current market price for the rebuild.
necromancer is offline
Rebuilt turbo Diesel on Ebay MR. MUD Unimog 0 09-19-2007 08:43 AM
Diesel w124 300TD Burning a lot of oil ... what does a rebuild cost? ajax00 W124 E,CE,D,TD Class 5 08-17-2007 03:27 PM
Looking for a Sprinter Rebuilt engine Monstermog1964 W901-905 Sprinter 0 07-04-2007 09:09 AM
300TD rear suspension overhaul cost Niloc W123 E,CE,D,CD,TD,TE Class 10 01-16-2006 01:47 PM
engine and transmision rebuilt G1979 G-Class 4 08-31-2005 12:09 PM
