Manually operate soft top on 1994 e320? - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 05-13-2009, 08:58 AM Thread Starter
Date registered: May 2009
Hi my 1994 e320's convertible top will not open, is there any way to lower the top manually?
I see this has been covered in a previous thread but does not answer the question as to wheather its possible to crank the top down manually.
http://www.benzworld.org/forums/w124...on-1994-a.html
elic0 is offline
post #2 of 3 (permalink) Old 05-13-2009, 09:34 AM
Date registered: Dec 2006
Vehicle: 1994 E320 Convertible, 1996 SL500, 1992 300TE 4Matic
No. You can only put the top up manually. Besides, why do you want to open it manually? If it does not work, you have to fix electronics or/and hydraulics. These tops and not fun to operate manually.
KBelov is offline
post #3 of 3 (permalink) Old 05-14-2009, 05:57 AM
Vehicle: 95 E320 Cabriolet, 106K
I suppose the top can be operated manually. It would be cumbersome and you'd never be able to latch the rear bow with the top up.
Kestas is offline
How to remove the hard top and put the RST (roadster soft top) up manually lynns R129 SL-Class 55 04-04-2016 08:35 AM
W124 soft top manual operation 1994 E320 Cabriolet KBelov W124 E,CE,D,TD Class 207 05-06-2015 05:58 AM
Manually locking the soft top front and rear. lynns R129 SL-Class 18 02-22-2015 12:42 PM
Soft Top Problem with 1994 royvan R129 SL-Class 17 08-14-2008 04:42 PM
Tool to Manually Close Soft Top StatManSL R129 SL-Class 1 04-14-2006 03:56 PM
