replacing fender on w124 wagon - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 03-14-2009, 07:06 PM Thread Starter
Date registered: Feb 2009
Vehicle: 1980 450sl
i recently purchased a 1994 w124 wagon - the first older car i have ever had, which i am looking forward to working on and learning from. the right front fender was scraped and subsequently repainted at some point before i bought it, and I am thinking about replacing it. some questions for you all:
> i have heard this is a relatively easy job given fenders are bolt-on. can anyone confirm?
> any instructions available, or will i have to guess my way through the process?
> i know i can get a pattern part on adsit, which i heard are relatively decent (?). i would prefer getting used oem, but the only ones i can find are on sedans. will the right front fender from a 94 e320 sedan fit on my 94 e320 wagon?
> am going to find a body shop to paint it. do i do that prior to or after installing fender on the vehicle? if i get a used part (rather than pattern part), am i better off bringing to shop to prime it first before I install it?
as you can tell i am new to all this. if there is an easy source for figuring this stuff out I would appreciate your guidance. in the meantime i appreciate your patience with what may be stupid questions.
thank you much.
cyall8r is offline
post #2 of 5 (permalink) Old 03-14-2009, 07:54 PM
Cruise Control
Zeitgeist's Avatar
Date registered: Sep 2004
Vehicle: '87 300TD/'90 300D/'94 Quattro/'89 Vanagon TDI/'01 EV Weekender VR6
Quoted: 1647 Post(s)
Yes, these fenders simply bolt-on, and are interchangeable between sedans and wagons. Check out the DIY sticky at the top of the 124 main page for a link to an online manual that can help you remove the fender. Since you're relatively new to all this, I'd leave the prep work to the pros, since that's the most important part of any bodywork task...it's also the most expensive, so you may want to research body prep, first.
Zeitgeist is offline
post #3 of 5 (permalink) Old 03-14-2009, 11:40 PM
Cyberbach's Avatar
Date registered: Sep 2005
Vehicle: 1995 E300D
Quoted: 2 Post(s)
What kind of experience have you had with bodywork in general. Mercedes cars do bolt up nicely and are a pleasure to work with but replacing a fender can be a bit daunting for the inexperienced DIY. The fender is physically glued onto the inner fender and is a bit of a bear to remove before the replacement can be fitted into place. You have to have a pretty good feel for sheet metal to get everything fit correctly and prepped to prime. Front fenders are usually pretty clean in junk yards and I would start there before buying a replacement aftermarket fender. You'll have some "waves" to work out irregardless but it seems used parts are a little heavier and less expensive to begin with. If you have a pick - n - pull yard take a small magnet with you and test for body filler towards the lower sections of the fenders till you find a clean one. You should be able to buy it for around 100, but like I said, cutting it loose from the inner fender can be a real bi*ch. You'll figure out how much of a job it is when you go about removing the existing fender from your car. There are panel bolts inside the edge of the door, under the bottom trim panel, inside edge of hood and around the headlight doors. Good luck and post questions if you have them, someone will always be able to help.
1981 240D---234K - They said she was too far gone to be brought back ......... she lives!!! http://www.benzworld.org/forums/w123...completed.html
1983 300TD--103K
1995 E300D--162K
Yea these cars will last a million miles but what with terrorists, natural disasters and the H1N1 swine flu pandemic... God help us there's anyone left here to drive them.
Cyberbach is offline
post #4 of 5 (permalink) Old 03-15-2009, 07:09 AM
augapfel's Avatar
Date registered: Jan 2006
Vehicle: About a dozen 1988, 1989, 1990, and 1991 sedans, wagons, and 4Matics; drivers, projects, and parts
Quoted: 20 Post(s)
It's quite easy to replace a front fender on the 124. As far as Cyberbach's "gluing" statement, I've never seen it (on a 124). On every early 124 I've worked on the fender is simply hung on the inner fender flange and then bolted in place. No glue/sealant. Maybe the 90-up are different?
Sedan fenders *are* the same as wagon fenders. As are the hood, front bumper, grill, headlamps, front doors, windshields, front seats, and lots of other stuff.
The procedure my be in the DIY section so do look there. Basically you loosen or remove about 7 front bumper cover bolts to reposition it. You remove the turn signal assembly, the headlamp wiper, and the headlamp assembly. Then you remove about 10 small bolts/capscrews to free the fender. You lift the fender off the inner fender and you're done. There is a plastic partial inner fender and a rubber sealing strip attached to that but you don't have to mess with those.
Try U-Pull-It yards for good used parts cheap. I paid $30 for the last one I bought and it was perfect with original paint. I think you're better off buying a used part since they are already treated with antirust stuff on the back side and will be better prepped and primed than any new replacement part will be.
If you're patient you have a fair chance of getting a part of the same color as your car (I did). Of course that depends on whether you hae a common color like white, black, smoke silver, etc. If you have pajet red metallic, minty green metallic, petrol blue green, or something like that expect to repaint what you find.
augapfel is offline
post #5 of 5 (permalink) Old 03-15-2009, 07:15 AM
Cruise Control
Zeitgeist's Avatar
Yeah, I don't believe 124s use glue, but oh if they did, you'd rue the day you set out to undertake that job. I once dismantled an old rusty '78 W123 and I think it was the most frustrating automotive task I've ever encountered. The glue was thick and ever so stubborn. Heat, packs of razor blades and a whole lotta cussin'...never again.
Replacing W124 wagon hatch struts Pretorien W124 E,CE,D,TD Class 30 11-04-2014 06:12 AM
Where to buy W124 Fender & Bumpers in SEATTLE? racing_maven For Sale/Wanted/Trade/Giveaway 0 03-14-2009 04:56 PM
diesel fender for non deisel w124 pyro_la W124 E,CE,D,TD Class 9 04-22-2007 10:30 AM
Replacing fender panels... montyhall2k W123 E,CE,D,CD,TD,TE Class 3 12-05-2004 05:35 PM
AMG 6.0 Wagon issues- cooling, fender rubbing Guest (MBNZ) W124 E,CE,D,TD Class 4 01-04-2002 11:29 AM
