1987 260E Problems - Mercedes-Benz Forum
post #1 of 9 (permalink) Old 03-08-2009, 03:04 PM Thread Starter
Date registered: Feb 2009
Vehicle: 1999 S320
1987 260E Problems
I have a 1987 260E. Has about 229,450 on the clock. It has been a great car. It's now getting to the point where I want to fix the little things that are wrong with it to make it a great car. Although its not my every day car I want to get it back up to snuff. There are two major problems and a couple of small minor ones that are keeping this from being great. If any of you guys could tell me how to fix or what to look for with any of these problems I would sincerely appreciate it.
1. Hard Starting this car can be a real pain to start sometimes. Sometimes it will start right up and idle pretty good. Other times you have to keep cranking it over and over about 2 or 3 times with the pedal pressed half way down to get it to start up. After that it starts ok. The fuel pumps are new, the OVP relay was replaced about 5 years ago and its the one with the Red Cap. The fuel pumps and filter were replaced 2 years ago. The plugs, wires, cap, rotor and alternator were all replaced back in June (9 Months ago). Was starting rough then too.
2. The cruise control isn't working quite right. I tried replacing the amplifier and sometimes it will accelerate and not hold. Other times it will accelerate and hold but be jerking. I looked in the Mercedes service manual and it said it might be the Hall Sensor behind the Speedometer others have said try another amplifier. Im starting to get confused. LOL
3. The SRS light is stuck on. How do I go about finding out the problem.
I know its a 22 year old car and im not surprised that there are problems with it. Its just I want to get a well running car and get that longevity the 124 is known for.
California260E is offline
post #2 of 9 (permalink) Old 06-02-2009, 03:06 PM
dallas260e's Avatar
Date registered: May 2009
Vehicle: 1988 260E
with the SRS, you will need a diagnostic check to find the fault.
usually means there is a low voltage problem with the airbag or seat belt sensors.
1988 Mercedes Benz 260E
dallas260e is offline
post #3 of 9 (permalink) Old 06-02-2009, 05:08 PM
GHM
GHM's Avatar
Date registered: Jul 2005
Vehicle: "Gretchen" my 1986 300E 286000 km+ (RIP) August 2015
Quoted: 24 Post(s)
Post
Well lets start here, you are not in denial that the vehicle is 22 years young. When I first bought my auto back in 2005, similar problems as you have. I would start with the cold start valve and then progress up to the fuel injectors, to see if they are both operating to there full potential. My auto has been a project car for the last 4 years and slowly but surely its running fine. Then or before you may want to look in the DIY for info on fuel distributor adjustment. Good luck
Remember the way things used to be, we can never get that time back,so make the best of the time you have now, Life is short!, Break a few rules! Forgive quickly! Love truly, Laugh uncontrollably ... Good times become good memories bad times become good lessons.
GHM is offline
post #4 of 9 (permalink) Old 06-03-2009, 06:53 PM
ath20wj's Avatar
Date registered: Mar 2009
Vehicle: 1987 260 E
Quoted: 17 Post(s)
ha, we have the SAME car, lol. Ive never seen another 87' 260E... well... I never see 260E's but yeh, I hav the same starting prblm to, it alweighs starts, it just takes it longer sometimes.
I don't think it would be a good idea for me to create a signature. It would probably just be some shameless plug about me being a Realtor.
ath20wj is offline
post #5 of 9 (permalink) Old 06-03-2009, 08:22 PM
necromancer's Avatar
Date registered: Aug 2007
Vehicle: 1990 Mercedes Benz 300E
Your hard starting problem might be related to the ignition coil, type of plugs (non-resistor is recommended), cold start valve, coolant temperature sensor, or idle control valve, could also be loss of signal from crankshaft position sensor... does it sometimes die on the road?
Your cruise control problem is likely related to a burned out cruise actuator if it is "hunting" for the setting. Get ahold of the owner of GDL.
General Development Laboratories - Table of Contents
This is the best outfit to go to for fixing your cruise... if you describe your problems thoroughly to him you will get a very accurate assessment. From my experience... hunting is synonomous with burned out traces on the actuator. With your mileage this is totally feasible.
necromancer is offline
post #6 of 9 (permalink) Old 04-06-2010, 12:53 PM
Date registered: Apr 2010
I was looking at picking up one of these used....what should I look for as far as "Red Flags" go?
Thanks for any input you guys can give.
ZRob72 is offline
post #7 of 9 (permalink) Old 04-06-2010, 08:28 PM
ps2cho's Avatar
Date registered: Oct 2006
Vehicle: 2008 E350 4M, 1988 300TE, 2005 ML350
Quoted: 234 Post(s)
Exactly the same issues as the 300E. The 2.6 is no different.
ps2cho is online now
post #8 of 9 (permalink) Old 04-06-2010, 08:49 PM
I'm new to Mercedes cars so what problems would that be?
ZRob72 is offline
post #9 of 9 (permalink) Old 04-09-2010, 07:16 AM
Date registered: Mar 2010
Vehicle: 1995 E320 sedan/ black with black interor
did you ever change your wireing harness, it could be that your harnessis simply shorting out. dose it start better when it is warm. because if so the fuel ratio when cold starting might be off. the car is suposto have a richer ratio when cold.
danyablon is offline
    1987 260E Good Shape LGF For Sale/Wanted/Trade/Giveaway 1 06-19-2008 04:44 PM
    1987 260e. Still has some problems. Darkwind W124 E,CE,D,TD Class 1 03-14-2008 09:28 AM
    1987 260E cd wiring adamae W124 E,CE,D,TD Class 1 09-18-2005 09:15 PM
    1987 260e Window probs Rainwarrior W124 E,CE,D,TD Class 1 11-21-2003 06:29 AM
    1987 260E merc03 W124 E,CE,D,TD Class 2 04-15-2003 07:38 AM
