I'll be posting in this thread about my upcoming engine swap, in which I'll modify a recently acquired '99 OM606 Turbo and install it in my '87 300TD.
I've been steadily upgrading the chassis for this swap, including an intercooler, a Sportline suspension rebuild, Limo/500E swaybars and SL600 brakes. Now I'm ready to take it to the next level, that I'm targeting to run in the 300hp to 350hp range.
Current engine:
OM603 (3.0L 12v) with a stock rating of 148hp [theoretical maximum modified output ~450hp]
I've tweaked the pump so that output is now somewhere in the 170hp-180hp range. When I flip the propane switch, it may run anywhere near 200hp. This is the original engine with 232k miles. Runs great and uses very little oil...drips well, that's another story.
Donor engine:
OM606 (3.0L 24v) with a stock rating of 175hp [theoretical maximum modified output 500+hp]
This engine was originally designed to be a drive-by-wire setup, so I'll be installing a mechanical injection pump from an OM603. I'll temporarily be using a slightly tweaked stock pump with 5.5mm elements, but will be sending off the unit that's currently in my wagon to Finland, where they'll install 7mm elements. The real limitation to power output is the tiny little KKK turbo that's currently on there. This won't suffice once the modified pump is fitted, so I'll need to investigate a more suitably sized model before the pump is sent back. The engine has just 78k miles on it, and it's dry as a bone.
Modification unknowns:
Oil pan Needs the 603 version swapped over, 'cause the 606 is a different shape. Will also need the oil pump swapped Oil filter housing Needs the 603 version swapped over, 'cause the oil cooler lines interfere with the cruise actuator
Cruise actuator Needs to be slightly modified 'cause the upper lefthand mount interferes with head
Throttle arrangement still unknown
Engine mounts Needs the 603 versions swapped over
Flex plate Needs the 603 version swapped over
Temp sensor locations I'm just using the 603 coolant temp and Aux. fan sensors
Serpentine belt issues Needs the 603 H2O pump pulley swapped over, 'cause the 606 version is smaller
Wiring (minor) This is an opportunity to clean up the stock wiring and eliminate the un-needed EGR management stuff
Minor update:
I'm most of the way through dismantling the 603 and intend to pull it sometime this week. I certainly won't miss the myriad of leaks from both the engine (front seal, lower IP seal, tandem pump, etc) and transmission. I've secured a ~6k mile rebuilt 722.3 with beefed up internals to sit behind this unit, so the entire drivetrain (short of an LSD upgrade) will be updated and hopefully leak free.
One new unknown regards what to do about the stock 606 turbo. These things are tiny and have a vacuum as opposed boost activated wastegate. The latter issue is relatively easy to rectify, but the small size is problematic, especially if more fuel is added. I'm seriously considering running tandem turbos in series, like this:
For simplicity sake, I'd probably just run with one intercooler. I'm thinking the stock turbo wouldn't have to be disturbed, and the primary unit would sit almost directly above. Not sure what size I'd use, but I think the trickiest part will be to get it to mount up securely, so that the plumbing doesn't bear the full weight of the turbo. I think it's obvious that just fabbing up a custom header with one properly sized turbo would be easier, but that's expensive and not really something I feel that I can do with my rather limited MIG skillz. I'm still working on this, so feel free to jump in and let me know how stoopid this sounds.
I still need to either have my stock IP sent off to Finland for the 7mm elements andexternal adjuster, or have the 6mm elements from the 606 IP swapped over. I prefer the former, 'cause I really want that external adjustability.
That spring block is intended to increase the lockup of a limited-slip diff (either LSD or ASD), not convert an open diff into LSD.
I've installed a factory LSD in both my 1987 300D and 1994 E500, and I'll be happy to assist Casey when he's ready to go down that path... it was a fantastic upgrade for my 300D. The E500 already had ASR, so the LSD simply helps for racetrack use (no improvement on the street - ASR already works great on the street).
__________________ Dave M.
Boise, ID
1995 E420 - 196kmi (Quicksilver)
1995 E420 - 178kmi (For Sale)
1994 E500 - 111kmi (Q-ship)
1992 500E - 171kmi (Mach 5)
1987 300D - 313kmi (Sportline Stage 2) Click here for my "website"
Hey dude, thanks for the update. Let me know what you find at the shop. I'm getting ready to unload all sorts of OM603 stuff, including two trannies, an updated vacuum pump, modified intake manifold, #22 head (Dave has first dibs), injectors, glow system (relay, wiring and plugs), updated H2O pump housing and newer pump (beefier), etc.
