How to remove the CPS? - Mercedes-Benz Forum
post #1 of 7 (permalink) Old 02-23-2009, 08:52 AM Thread Starter
QuangsBenz's Avatar
Date registered: Mar 2006
Vehicle: 89 300E
I'm getting a new CPS today, and if it doesn't rain I will be replacing it. I notice that the oil filter is in the way and I might have to remove the filter before I can get access to the CPS, but I'm not sure. Does it require the oil filter to be removed first? If you have any hints & tips on replacing the CPS please let me know.
Thanks,
Quang
QuangsBenz is offline
post #2 of 7 (permalink) Old 02-23-2009, 09:23 AM
tuttebenne's Avatar
Date registered: Jul 2005
Quoted: 241 Post(s)
Thanks,
Quang
I think I took mine off when changing the CPS but not sure if you HAVE to. It just seemed easier with it out of the way.
'89 300E
'90 300CE
'93 400E
'93 500E
'00 E320
'73 Alfa GTV
'77 308GTB
tuttebenne is offline
post #3 of 7 (permalink) Old 02-23-2009, 01:20 PM Thread Starter
QuangsBenz's Avatar
Vehicle: 89 300E
Why did you change yours? Just curious. Was it because of a hard start or sudden stall problem?
post #4 of 7 (permalink) Old 02-23-2009, 02:52 PM
tuttebenne's Avatar
Quoted: 241 Post(s)
No, mine was dead. It turned out that the problem was a bad coil.
'89 300E
'90 300CE
'93 400E
'93 500E
'00 E320
'73 Alfa GTV
'77 308GTB
post #5 of 7 (permalink) Old 02-23-2009, 08:01 PM Thread Starter
QuangsBenz's Avatar
Vehicle: 89 300E
I just picked up my CPS, but have to wait until tomorrow to install it. I hope this is the last item I have to change to make it run again, and hope my coil is okay.
How did you find that your coil was bad?
post #6 of 7 (permalink) Old 02-24-2009, 09:18 AM
tuttebenne's Avatar
Quoted: 241 Post(s)
I don't think my method will help you because I have a few 124s and I just swapped coils with my wife's car and found that it was dead. Don't ask me why I didn't do that before replacing the CPS (!)
'89 300E
'90 300CE
'93 400E
'93 500E
'00 E320
'73 Alfa GTV
'77 308GTB
post #7 of 7 (permalink) Old 02-24-2009, 08:49 PM Thread Starter
QuangsBenz's Avatar
Vehicle: 89 300E
I attempted to remove my old CPS today without luck. I have the correct bit connected to a u-joint with a 12-inch 1/4" extension bar. The hex screw didn't want to turn. I was afraid that I'd strip the screw's hole. I sprayed some super lubricant hope it'll come out tomorrow.
There's not too much room in there. How did you manage to take yours out? What tools did you use?
    CPS dlbehrns C208/A208 CLK-Class 0 01-01-2009 07:35 PM
    CPS mishael W202 C-Class 1 10-02-2008 11:43 PM
    CPS failure symtoms but it's not the CPS problem joeml W163 M-Class 3 06-05-2008 11:05 AM
    CPS ADCastro W210 E-Class 4 05-12-2008 01:21 PM
    Need a CPS? ganndallff R170 SLK-Class 2 12-10-2007 02:38 AM
