w124 td diesel tank filter - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 01-30-2009, 12:15 PM Thread Starter
Date registered: Dec 2007
Vehicle: 250 TD W124 RHD 1989, E300 TD 1999
Hi,
I have a 1989 250 TD and have been having some problems with fuel blockages. ( see previus post for details)
Anyway I finally got the towbar undone enough to be able to get at the drain plug under the diesel tank. Next problem is I can't shift the plug at all.
1) can any one confirm that the plug undoes anticlockwise as seen from below (spent a lot of time there today ;-) ) ?
2) any hints on getting the thing to move - I tried heating it up a bit with a blow torch but didn't want to over do it ?
TIA
Nick
nickdub is offline
post #2 of 6 (permalink) Old 01-30-2009, 03:20 PM
rodnex's Avatar
Date registered: Oct 2007
Vehicle: E36T AMG, 500GE
1. yes
2. just a big wrench
3. be careful - you have not full tank
rodnex is offline
post #3 of 6 (permalink) Old 01-31-2009, 02:37 AM
Date registered: Apr 2008
Vehicle: 1995 E300D W124
I hate to add to your woes, but after you've cleaned the tank filter & got everything running OK, beware of the injector spill pipes blowing off! My 300D had this problem a few hundred miles after I bought it and I eventually discovered that the fuel return line was blocked at it's end, inside the fuel tank!
Apparently the car had stood for 2 years with very little fuel in the tank and algae had grown in there. Somehow,, it was able to get through the system, but finally caused a blockage - and it also messed up the fuel level sender! The float was stuck to the bottom of the unit, but I managed to free it up. (I cured the blockage by cutting the plastic return pipe inside the tank!)
zanimat is offline
post #4 of 6 (permalink) Old 01-31-2009, 02:19 PM Thread Starter
Hi,
Thought some people might like to see the full horror of the strainer as extracted this morning :-)
[IMG]c:\photos\merc strain.JPG[/IMG]
Most of the gunge peeled off in a layer about 1/8 th inch thick
The car has enough power now to drive up the hill where I live - which is nice.
PS I have now swapped out all the non-metallic parts of the fuel system for new replacements, having previously done all the front lines.
Name:	merc strain.jpg
nickdub is offline
post #5 of 6 (permalink) Old 01-31-2009, 02:24 PM
Cruise Control
Zeitgeist's Avatar
Date registered: Sep 2004
Vehicle: '87 300TD/'90 300D/'94 Quattro/'89 Vanagon TDI/'01 EV Weekender VR6
Quoted: 1550 Post(s)
Wow, I'd say you hit the jackpot right there!
Zeitgeist is offline
post #6 of 6 (permalink) Old 02-01-2009, 05:00 PM
curlytom's Avatar
Date registered: Oct 2006
Vehicle: 1995 E300 Diesel
That is incredible! I sure wish you had taken some pics of the job - after seeing yours, I may want to pull my tank strainer just to check its condition.
1995 E300D Special Edition
2002 GMC, 4X4, Crew Cab, Long Bed, 6" lift, 35" tires and lots of other goodies.
curlytom is offline
    Silt in diesel tank warren032 W210 E-Class 21 10-10-2008 10:10 AM
    need to return diesel to tank billysdad W123 E,CE,D,CD,TD,TE Class 7 10-01-2008 06:20 AM
    Diesel tank line WeVonBraun W123 E,CE,D,CD,TD,TE Class 4 07-10-2006 05:38 AM
    Diesel tank venting Crashmaster Unimog 4 07-04-2005 09:40 PM
    diesel tank capacities dipple G-Class 4 04-18-2003 02:32 PM
