Trunk won't close - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 01-27-2009, 12:09 PM Thread Starter
Date registered: Jan 2009
Vehicle: 1995 Mercedes Benz E320
Send a message via AIM to realhorrorshow88
Trunk won't close
Hey, I just inherited a 1995 Benz E320 and the trunk will not latch!
Well, I lied, I got it to latch but I had to like slam it, or do like a freaking magic trick to get that thing to close.
Any advice? lithium grease? WD 40? oiling it up?
realhorrorshow88 is offline
post #2 of 6 (permalink) Old 01-27-2009, 07:29 PM
augapfel's Avatar
Date registered: Jan 2006
Vehicle: About a dozen 1988, 1989, 1990, and 1991 sedans, wagons, and 4Matics; drivers, projects, and parts
Quoted: 19 Post(s)
The latch or striker may need to be adjusted. Or the latch may just need some lub as you mentioned. Regular oil will work fine for that. The rubber bumpers at the trunk corners are adjustable and used to set closed lid height. Does it seem like the lid is high when closed? If so the bumpers may need to be loosened and lowered.
Mind you, this thing was right when it left the factory so your problem almost certainly results from lack of lubrication or body distortion from collision damage.
augapfel is offline
post #3 of 6 (permalink) Old 01-28-2009, 08:49 PM Thread Starter
actually it gets more interesting
So I am able to close it but it pops open even when it appears to be latched! I was entering the freeway and sortve went fast on a dip and it popped open, I got it to close again by pressing down on the hood so that it would latch, and nothing's happened after that.
The peculiar part is that before the trunk popped open before the freeway, I was unable to even open my trunk. I pressed the button for it to open, tried locking/unlocking it from the trunk but it just would not open.
So do you think it's more than just a lacking lubrication?
post #4 of 6 (permalink) Old 01-28-2009, 08:58 PM
alexnatt's Avatar
Date registered: Feb 2004
Vehicle: 2000 e320 4matic
Do you drive a benz or a Durango 95?
2008 E350 4matic wagon
2000 E320 4matic wagon (sold)
2001 E430 4matic sedan (sold)
1989 300SE (sold)
1994 E420 (sold)
1988 300TE (sold)
alexnatt is offline
post #5 of 6 (permalink) Old 01-28-2009, 11:07 PM
merc-one's Avatar
Vehicle: 1988 300E, 2006 E350 wagon
i'd start with some lube. i always start with lube...
joking aside, if it looks dry in there or gunked up just clean it up and lube it good. i think you can try tripping the latch and opening it a few times with the trunk lid open to make sure the mechanism is moving freely.
if this doesn't do the trick, then i think you have a problem with the latch not aligning with the striker. getting these things aligned seems like it could be fairly tricky.
2006 MB E350 wagon
1988 MB 300E
1997 Volvo 854 -- RIP
1992 Saab 900s Turbo -- RIP
1988 Saab 900s -- RIP
1987 Volvo 245 -- RIP
2000 Aprilia Pegaso 650 -- sold
merc-one is offline
post #6 of 6 (permalink) Old 01-29-2009, 08:57 AM
augapfel's Avatar
Quoted: 19 Post(s)
Now it sounds even more like a bindin/lubrication problem. What probably happened when you pressed the release button initially is that the latch partially unlatched but was binding. Driving the car motion caused the latch to eventually release. Still binding, it was a pain to get it to latch again.
Get the lid open and take a look at the latch moving parts. Maybe someone slammed the lid on luggage or debris and the latch is jammed with some crap. I'm betting that's the problem. Hopefully nothing got horribly bent.
augapfel is offline
    Trunk Close Assist z168 W140 S-Class 23 05-10-2009 04:30 AM
    Trunk wont close..help!! Syracuse315 W201 190-Class 13 12-09-2005 11:02 AM
    How hard to close trunk? mtiede R171 SLK-Class 14 11-08-2005 02:28 PM
    Trunk close problems.....yet again.... Jamison W140 S-Class 5 01-09-2005 08:42 PM
    Trunk will not close all the way jhaskin W140 S-Class 7 02-10-2004 10:40 PM
