300e cold start question - Mercedes-Benz Forum
post #1 of 16 (permalink) Old 01-22-2009, 11:01 PM Thread Starter
Date registered: May 2005
Send a message via MSN to benznawz
my 300e has always had problems starting when cold and finally i checked to see whats wrong with it the first thing i did was test to see if the cold valve injector is getting any power to it and sure it enough it isn't.I tested another 300e and its getting 11 amps when u turn the key on with out starting so i figure its one of my relays which one could it be OVP? fuel pump relay? what u guys think
benznawz is offline
post #2 of 16 (permalink) Old 01-23-2009, 05:46 AM
RBYCC's Avatar
Vehicle: 88-300CE TWIN TURBO, 99-C43, 05-G55K, 71-280SL, 94-E320 CAB, 08 CLK63 BLACK SERIES
The cold start circuit begins with the engine temp sensor.
TURBOTECHNICS TWIN TURBO M103 WIDEBODY
1971 280SL ROADSTER
1988 300CE TT WIDEBODY COUPE
1994 E320 CABRIOLET
1999 C43 AMG SEDAN
2005 G55K AMG TRUCK
2008 CLK63 AMG BLACK SERIES COUPE
RBYCC is offline
post #3 of 16 (permalink) Old 01-24-2009, 03:11 AM Thread Starter
so if this sensor is dead cold calve wont work or get any power to it? and where can i find this temp sensor?
benznawz is offline
post #4 of 16 (permalink) Old 01-24-2009, 04:33 AM
Jayare's Avatar
Date registered: Jun 2005
Vehicle: 86 190E 2.3L 16V, 93 400E, 95 320TE, 95 E320, 98 S500
Quoted: 687 Post(s)
The engine temp sensor is the last one on the head, nearest the firewall. Inexpensive.
Good Luck,
Jayare
Jayare is online now
post #5 of 16 (permalink) Old 01-26-2009, 12:16 AM Thread Starter
isn't engine temp just to show u the temp of the engine? or does it do something more the car feels like its lacking fuel when its cold i can put my foot down all the way and it will not pull just rev up slowly and not even smoothly.Im gonna take it in tomorrow to see what they can find out bc its getting worse now it has to warm up up to 80 to have its full power anything under will not pull.
benznawz is offline
post #6 of 16 (permalink) Old 01-26-2009, 01:34 AM
Jayare's Avatar
Quoted: 687 Post(s)
You hit the nail on the head. The engine temperature sensor has much more to do with the fuel management system than you realize. It's purpose is to provide information to the ECU for fuel mixture adjustments.
Fill out your profile. You should know that it will help us help you by now. How many miles are on your car? Heck, what year is it?
Jayare
post #7 of 16 (permalink) Old 01-26-2009, 01:07 PM Thread Starter
its 1988 300e with 135k I took it in today at my local benz mechanic and he has ordered ovp relay. He will put it in and try it tomorrow when it cold and he will adjust my fuel mixture.He he did mention the temperature sensor it might be faulty but will see if the relay does anything il let u guys know how it goes 100$ for the relay :0
benznawz is offline
post #8 of 16 (permalink) Old 01-27-2009, 06:28 AM
RBYCC's Avatar
He could have checked the OVP to see if he had voltage on pin 87V which feeds the cold start valve.
The Coolant temp sensor does not connect directly to the OVP, but to the EZL and KE control units.
1971 280SL ROADSTER
1994 E320 CABRIOLET
1999 C43 AMG SEDAN
2005 G55K AMG TRUCK
RBYCC is offline
post #9 of 16 (permalink) Old 02-01-2009, 10:52 AM
acha3's Avatar
Date registered: Oct 2002
Vehicle: 928S 1985 GS400 99 95 Miata M edition 944 n/a 1988 944 Turbo 87 300CE 1989 190E 2.6 1990
did the ovp solve your problem??
acha3 is offline
post #10 of 16 (permalink) Old 02-14-2009, 11:14 AM
Date registered: Jan 2009
Vehicle: 2001 E320 - 130000 miles
My 1993 300E , with CEL 8 and 28 also in the winter somtimes I had to crank the engine 2 or 3 times to get it start, after I read RBYCC post, I decided to do this : http://www.benzworld.org/forums/w124...ml#post3316771.
The CEL 8 and 28 were gone, and no more cool start problem.
I would like to say thanks to RBYCC post, without member like him I think I can not fix those prolems.(because I am a Saturday,Sunday mechanic :-))) )
LYLY is offline
Cold start 300E frobi W124 E,CE,D,TD Class 10 12-26-2008 05:47 PM
1990 300E cold start frobi W124 E,CE,D,TD Class 11 04-12-2008 08:00 AM
1990 300E cold start frobi W124 E,CE,D,TD Class 0 03-01-2008 12:38 PM
1992 300e cold start problem please help sixfeet750 W124 E,CE,D,TD Class 1 12-20-2007 07:04 PM
Hard start when cold 300E '86 paulb W124 E,CE,D,TD Class 1 06-20-2007 09:43 AM
