Elusive star adjuster for parking brake adjustment - Mercedes-Benz Forum
post #1 of 8 (permalink) Old 10-12-2008, 12:09 PM Thread Starter
Date registered: Dec 2007
I recently tried to adjust the parking brake on my '86 300E. I used the "remove lug bolt and peer" method often touted. However, I spent half an hour on each side, shining the flashlight into the hole and slowly rotating the wheel. But I never could spot the star wheel. I saw the holding springs, but that's all. As an old guy, I've done tons of star wheel adjustments on drum brake cars, so I know how they work. Is it perhaps better to remove the road wheel to get more access? Someone posted a pic with the rotor removed to illustrate the location of parts. It looked like the star wheel was in roughly the 11 0"clock position. But I couldnt find it on my car. The foot pedal goes down three clicks and stops, but the brakes won't hold an a slight grade. Hence, my quest.
rmr25 is offline
post #2 of 8 (permalink) Old 10-12-2008, 01:01 PM
jhodg5ck's Avatar
Date registered: Sep 2002
Vehicle: Depends on the day!
Quoted: 16 Post(s)
Send a message via AIM to jhodg5ck
I can't remember off hand if they are @ 11/1/?? o'clock on the 300E..
For the time you have invested thus far pulling the rotor would make things a lot simpler
Jonathan
Blue Ridge Mercedes/AMG East
Jonathan Hodgman
http://www.blueridgemb.com/
Enthusiast Service, Restoration & Tuning.
Authorized RENNtech Dealer & Installer
Follow Us on Facebook!
Located in the Atlanta area
87 Hammer Wagon 6.0L 32V
87 Hammer 6.0L 32V
86 560SEL AMG 6.0 32V
etc....
Mercedes Repair Atlanta
jhodg5ck is offline
post #3 of 8 (permalink) Old 10-12-2008, 02:52 PM
Jayare's Avatar
Date registered: Jun 2005
Vehicle: 86 190E 2.3L 16V, 93 400E, 95 320TE, 95 E320, 98 S500
Quoted: 681 Post(s)
Star wheel adjuster is at approx. 1 O'clock position. I have found it much easier to find with the wheel/rim removed.
Good Luck,
Jayare
Jayare is online now
post #4 of 8 (permalink) Old 10-13-2008, 12:40 AM
Jase's Avatar
Date registered: Jul 2007
Vehicle: 1998 C200 Classic; 1992 230E Sportline; 1994 C180 Classic (Sold)
I feel your pain! I did this on my car (230E). I tried with the wheel on but could also only see springs. So I removed the wheel and managed to find it. After that I could do the other side with the wheel still on.
I'm pretty sure mine was more of a 3 o'clock position... but may be different on a 230E? Wouldn't think so though. Either way with the wheel off you'll find it better
Jase is offline
post #5 of 8 (permalink) Old 10-14-2008, 06:32 AM
Date registered: May 2003
Vehicle: E320 wagon
Its better to pull the brake rotor and clean the mechanism . One side on my car was metal to metal and the cable was sticking on the right side. A good cleaning would help greatly , mine growled as the brake set / backwards roll. Thats all gone.
Uboater is offline
post #6 of 8 (permalink) Old 10-15-2008, 12:07 AM
Jase's Avatar
Can you explain the processs of getting the rotors off?
Jase is offline
post #7 of 8 (permalink) Old 10-15-2008, 04:16 AM
Vehicle: E320 wagon
Originally Posted by Jase View Post
Can you explain the process of getting the rotors off?
For a E320 , it may be the same for others.
Remove wheel - brake caliper unit ( keep the weight off brake hose )hang it on coat hanger or wire - remove the flush Allen bolts outside the wheel bearing cap - tap brake rotor off outward with a rubber or plastic hammer while turning it , in some cases a bit of heat from a propane torch is needed ( allen area ). Most come off quickly .
Make sure the brake is off and the other tires have bricks / 4x4 lumber to stop from rolling
Uboater is offline
post #8 of 8 (permalink) Old 10-15-2008, 12:43 PM Thread Starter
Friends:
I found the adjuster, as suggested, at the 1 o'clock position (driver side). But only with the wheel off. I could not see it otherwise. In any case, it's not all that eye-catching. When I have more time, I'll remove the rotors and clean everything up.
Thanks for your help.
rmr25 is offline
    Parking Brake Adjustment prevost3000 W201 190-Class 5 10-15-2010 02:01 PM
    Parking Brake Adjustment Winston W123 E,CE,D,CD,TD,TE Class 4 11-11-2006 02:08 PM
    parking brake adjustment joeb007 W202 C-Class 1 10-09-2006 02:35 PM
    Parking brake adjustment Geeky1 W126 S,SE,SEC,SEL,SD,SDL Class 7 01-09-2004 05:20 AM
    Parking brake adjustment Guest (MBNZ) W124 E,CE,D,TD Class 6 08-02-2002 12:19 PM
